  • June 23, 2025, 04:18:19 PM
Author Topic: Veco pistons  (Read 788 times)
Offline Russell Shaffer
Veco pistons
« on: August 06, 2007, 08:19:27 PM »
I have seen ways to "grow" a Fox, McCoy, etc piston.  Can anything be done with an old Veco 45?  I don't even know what that piston is made of, but mine could stand a little more compression.  Any suggestions will be appreciated.  Thanks.
Russell Shaffer
Klamath Falls, Oregon
Dave Adamisin
Re: Veco pistons
« Reply #1 on: August 07, 2007, 10:49:00 PM »
Hi Russel. This may seem a little mid-eval but I've had good luck on othe steel pistons using this technique. I take the piston (no pin) and balance it on an aluminum bar. I put about 6oz of 10w30 in a soup can. I then take a torch and heat the piston carefully untill it becomes deep red all over. I then quench it in the oil. It should grow. I have revived quite a few engines this way.
Re: Veco pistons
« Reply #2 on: August 08, 2007, 06:27:08 AM »
Hi Dave,
That sounds better than the "oven method". y1
