  • July 04, 2025, 03:42:16 AM
Author Topic: Os .25 differences  (Read 1246 times)
Offline Steven Kientz
Os .25 differences
« on: April 05, 2012, 03:17:35 PM »
I have 3 different OS.25. Two I know what they are for sure, a .25fp and a .25f. the third is SUPPOSE to be a .25fsr. On the case all it has is the vertical os max and the # 25 in a circle. I bought this at a swap meet in a .25fsr box, hope I wasn't duped.
Thanks Steve
Steve Kientz
AMA 855912
Re: Os .25 differences
« Reply #1 on: April 05, 2012, 03:21:02 PM »
Thanks Steve
Does it have ball bearings?
« Reply #2 on: April 05, 2012, 04:47:45 PM »
yes it and the .25 f have ball bearings. They are the same length(prop washer to backplate screws). Haven't been to the OS website to peruse pictures yet. Is there a case difference, such as larger runners giong to ports?
Steve Kientz
AMA 855912
« Reply #3 on: April 06, 2012, 06:06:46 PM »
The 25 F and the 25 FSR are pretty much the same engine.  The 25 F is ABC or ABN, and the head fins are just a hair taller.  The ABC construction makes for easier hot restarts and a little more RPM on the top end.  It's also a little more consistent.  The difference between the two is similar to the difference between an iron piston FP and an ABC (ABN) FP.
I have several of both the FSR and the F.  Both were run on a tuned pipe on a Primary Force ARF, and a Nemesis combat plane, with decent results (high RPM).  I always end up using the F over the FSR for the reasons I mentioned before.  With a wide open intake, bladder, no muffler and an 8" prop the 25F carried the Nemesis around the circle at around 93mph.  With the pipe, and a small venturi, the same engine was extremely consistent and carried the P-force like a good .40.
« Reply #4 on: April 07, 2012, 04:42:20 AM »
Thanks for the info, Andrew.  Its funny that a Nemisis is on my build list.
Steve Kientz
AMA 855912
