  • June 20, 2025, 01:26:44 PM
Author Topic: Difference between a Fox .29 Stunt and a Fox .35 Stunt?  (Read 6349 times)
Offline frank mccune
« on: October 03, 2013, 01:44:39 PM »
     Hi All:
     What are the differences between the two motors mentioned above?
     I think that the .29 had a thicker cylinder liner, different head, wrist pin and of course piston.  I think the crankcases were the same. Since one can not buy parts for the ..29, could one use .35 parts to convert the .29 to a .35.  One can still purchase parts for the .35.
        Just a thought,
        Frank
James_Mynes
Re: Difference between a Fox .29 Stunt and a Fox .35 Stunt?
« Reply #1 on: October 03, 2013, 02:50:29 PM »
Seems to me the 29 looked like the 36, bigger than the 35 over all. The 35 has a three bolt backplate, I think the 29 and 36 had four bolt backplates. I had a 29, but it was 30 some years ago, so my memory may be foggy.
« Reply #2 on: October 03, 2013, 06:11:05 PM »
  Depends on which 29 you are talking about. There were several, and one of them looked just like a 35 Stunt with a smaller bore. There was a later engine (70's) that was a 36 with a smaller bore.
steven yampolsky
« Reply #3 on: October 03, 2013, 07:20:04 PM »
What Brett said.
Many years ago on Stuka Stunt, there was a discussion on different versions of 29's. There were straight plugs and several slanted plug versions. Maybe you can find that topic in their archives
I had a 29 that made just as much power as a stock 35. It had a slanted glow plug.
« Reply #4 on: October 03, 2013, 11:28:20 PM »
It's not really worth the trouble.  For what you'll spend on a piston/liner set for the Fox 35, you could buy 2 or 3 good used Fox 35s on Ebay.
« Reply #5 on: October 04, 2013, 09:59:53 AM »
      Hi:
      i was asking about the Fox engines circa 1954.
      I have no intentions in making a .29 into a .35 but I was just curious as to what the differences were.
      Thanks for the replies.
        Frank
Offline 55chevr
« Reply #6 on: October 04, 2013, 04:43:26 PM »
If you have a Fox 29 with the short head bolts they are the same as the Fox 35 with short head bolts just smaller piston.  3 bolt rear cover.  I never noticed any difference in power between them.
Joe
Joe Daly
« Reply #7 on: October 08, 2013, 09:34:15 PM »
I had a Fox 29 that looked exactly like the 35.  It did have the same power, i.e. the plane could fly as fast, but the 29 wouldn't turn the same diameter prop.  I always had to go with a 9 in. prop.  it would just overheat on a 10 in. prop.  When I finally learned how to measure the port timings it looked like the 29 had more exhaust timing and a wider timing on the crankshaft port- timed for higher rpm.  Which makes sense because it was aimed at contest free flight where they needed high rpm and a low pitch prop.
« Reply #8 on: October 09, 2013, 06:44:12 AM »
     Hello Phil et al:
     Perhaps the old 50's Fox .29 engines were timed to run a bit faster than the .35 engines due to B Team Race applications. This was an event in the 50's that was really neat! The planes looked like planes and was not too fast to enjoy.  There were some really great kits that built into beautiful models.
     I also heard that the Fox .29 engines ran mor smoothly with less vibration that the .35 engines due to their lighter pistons.  Also the Peter C.F. Chinn reports always had the .29 engines peaking a bit slower than the .35 engines which made sense!
    I also think that the Enya .29 was faster than the .35 as it was designed for Class B Team Race. It had more horsepower than the .35!
        Stay well my friends,
        Frank
Offline L0U CRANE
« Reply #9 on: October 14, 2013, 02:05:41 PM »
Frank,
Duke Fox was pretty ingenious about using essentialy the same major pieces for various displacements. His small-case .40BB schneurles show family resemblance to some of the old square intake Combat Specials, for example.
The 4-bolt backplate baffle-piston .19 and .25 were nearly identical, except the .19 had a smaller bore. Not sure, but they may have had the same stroke. The stroke/bore ratio in the .19 may have been "square," i.e., equal bore and stroke. That made the .25 "over-square" - bore greater than stroke. The only difference between parts may have been a thinner cylinder wall and a matching piston for the .25.
The briefly offered .19BB schneurle looked a lot like the current .25BB schneurle, which has a longer stroke. The engine layout has a lower crankcase, and a finned spacer between it and the head. The .19's fin stack is shorter than the .25's. As I recall, the .25BB is "square" at 0.680" bore and stroke. The .19's shorter stroke would have made it "over-square."
Some Fox variants on a basic setup have a belly-band added around the lower case, apparently to fit a longer stroke...
Port timing is another factor. A shorter stroke may allow higher-RPM timing... Although the .25BB schneurle is also able to rev pretty high.
The slant-plug, baffle piston .29 and .36 from the '70's was a totally different design from the Stunt 35 and the 4-bolt backdoor baffle piston .19 and .25. Heavier. Mounting dimensions were quite different. Noticeably more power, and a reputation as shakers until well run-in.
The Stunt 35 is an example of how Fox continued using the same major pieces, with minor mods as needs appeared. Fifteen or twenty years back, I "overhauled" an early 4-bolt head, 3-bolt backplate Stunt 35 for an acquaintance in Connecticut. "Modern" - or at least currently produced - moving parts all fit. The shaft, piston and rod were different only in crankpin and piston pin diameters, and the prop driver. Replacement shaft with prop driver spline needed its matching drive washer: the original was a tapered pair - always fun to get the prop tight where you could flip it for starting, and where it would stop flat so you didn't bust one every landing.
Had to use the 4-bolt head - they just aren't available any more.
\BEST\LOU
Offline Bill Mohrbacher
« Reply #10 on: October 16, 2013, 06:08:30 AM »
Externally the 29 stunt is identical to the 35 stunt except the "35" is ground off the bypass and 29 stamped in its place.  The picture shows a 1958 29 stunt, the last version made.  Earlier "sandcast" 29s had a "29" stamped on front of the exhaust stack; the 35s had NO markings.
The 29 used the 35's case with all dimensions identical to the 35.  This means the 29 liners were thicker than the 35s.  To lighten the engine up a bit, Fox undercut the 29 liner in two places as the picture shows, but the 29s were still a bit heavier than the 35s.
Fox made 29s in all the case styles in the photos.  The 1984 BB was the last Fox 29.
Offline Ward Van Duzer
« Reply #11 on: November 04, 2013, 12:13:04 PM »
The 4 bolt 29's used for speed and "B Team Racing" were Fox 29R's. Much hotter than the plain 29's.
W
« Reply #12 on: November 18, 2013, 06:27:13 PM »
The stunt 29 was used to allow flying on thinner lines when line size was tied to displacement. It would pull a medium 35 size ship (like the Still Stuka). The down size is it was about 1/4 oz heavier than the 35.
Best,      DennisT
« Reply #13 on: November 24, 2013, 03:22:01 PM »
I don't recall a line rule that ever allowed smaller lines for .29's than .35's. It was only recently that .012's became allowed for .25's, after all.
I had a Fox .29 Stunt when I was in HS, that I bought in a Pawnshop in Oak Harbor (always check Pawnshops near military installations!) for $6, near new. I don't recall the reduced diameter area on the liner as shown in the picture above. I much preferred my Fox .201, which was really just a .19 with .201 stamped on the side.  H^^ Steve
Offline David_Ruff
  • David Ruff
  • Retired Army
« Reply #14 on: January 05, 2014, 04:32:31 PM »
just starting to come here to this forum...reading about the .29.
I am posting a photo of one I bought.  I have never run this engine.
So you experienced folks please tell me about this one....
I also have a Fox .19 I am posting a photo of here.  Again, new to me and never run..yet.
any comments on this .19 appreciated.
Just glad to be here
Offline Bob Matiska
« Reply #15 on: January 09, 2014, 07:18:49 AM »
I have one of the 29s and haven't run it yet, but also had the 36 version of this engine and used it quite a bit. They're decent sport engines that require a proper breakin, then can be used on a sport model. Note that they are not "stunt" engines in that they don't give the 4-2-4 run of a Fox 35, for example. They also vibrate quite a bit. Good luck finding a muffler for it, btw. Fox made open and closed front silencers for this series, but they haven't been available in many years. If you do find one, hopefully it'll be the closed front muffler, as my open front unit didn't muffle much at all, even after I packed it with copper wool.
I also bought one if the 19s many years ago and still have it. Again, it's an iron piston engine that requires breakin. I flew mine on a Goldberg Junior Satan and it worked well. Eventually added a Veco carb via a homemade adapter and used it on a Sturdy Birdy I built for my son 20 years ago. It worked well on that, too.
Bob in NEPA
AMA 56267
Offline Garf
    • Hangar Flying
« Reply #16 on: February 04, 2014, 04:08:02 PM »
The 36 slant plug ran well, but liked to throw cranks when pushed. I have one now that sounds like a bucket of bolts.
Offline Bob Matiska
« Reply #17 on: February 04, 2014, 05:14:34 PM »
I hogged out the venturi on my 36 with a Dremel tool until it was square, and about as open as it could get without destroying it. Flew it on a VooDoo with a Tornado 8-8 prop, lots of nitro (Rogo 58%, I think) and no streamer and my buddy clocked it at 118mph. To this day, I suspect he timed it for 6 laps instead of 7. I dunno. I eventually got a new crankcase for it and transferred the parts. I ran it many times after that and gave it away on a Cosmic Wind a couple of years ago.
AMA 56267
Offline David_Ruff
  • David Ruff
  • Retired Army
« Reply #18 on: February 08, 2014, 06:35:16 AM »
Just a dumb question about 4-2-4.  Why does that happen; that the engine picks up when put into a maneuver?  What is the physics behind that?
« Reply #19 on: February 08, 2014, 10:50:31 AM »
Quote from: David_Ruff on February 08, 2014, 08:39:22 AM
I will ask my dumb question here about the 4-2 break. What causes the break?  Is it the leaning of fuel mixture?  If so, how does that happen?  In a perfect world the fuel mixture should not change with a fixed system?
Hi David ,in a nutshell, it is a combo of things, load and mixture, the fuel head does change, as well as load when the airplane is in maneuvers, to see for yourself, run an engine on the bench, set it just in between a 4 and 2 cycle, raise only the tank up higher, then lower the tank only lower than the engine, you will see the engine go richer and leaner. you just changed the mixture.
Offline Timothy Payne
  • Mr Payne
  • Classic Racer
« Reply #20 on: February 26, 2014, 10:39:31 AM »
The main difference is the bore being slightly smaller on the 29 (I think!), I know the 35 stunt is 0.7" * 0.8" bore+stroke.
This is certainly the case with the 35(36X) and 29X motors that I use. - A good point to remember with the 29 is if you've got the same crank dimensions (stroke) as the 35, you've got a higher compression ratio.
Higher compression = More power! (You could even do what I did and make a headgasket from some 32thou aluminium sheet, thus detuning your 29 and making it 4/2 stroke like a 35 stunt.)
You'll find a photo of this gasket in the gallery (you'll need a hot plug though),
Tim
