  • June 21, 2025, 06:03:09 PM
Author Topic: OS 20FP manual?  (Read 1497 times)
OS 20FP manual?
« on: April 24, 2012, 03:21:40 PM »
Are there any of these scanned in out there?  I seem to know how to run the engine -- I just like to have the manufacturer's take on things...
Re: OS 20FP manual?
« Reply #1 on: April 24, 2012, 04:07:26 PM »
Tim, I believe that on OS website, there is a link for archives with PDF files of the manuals,, have you tried there?
Re: OS 20FP manual?
« Reply #2 on: April 24, 2012, 04:18:50 PM »
HI Tim,
The OS manual has no mention of the Brett Buck Tune Up in it.  ;D
BIG Bear
RNMM/AMM
Re: OS 20FP manual?
« Reply #3 on: April 24, 2012, 04:20:25 PM »
Or maybe cause I am SUCH a great guy, I will do the google for you,, and guess what,, on RCG I found this,,
Re: OS 20FP manual?
« Reply #4 on: April 24, 2012, 04:21:01 PM »
Or maybe cause I am SUCH a great guy, I will do the google for you,, and guess what,, on RCG I found this,, part two,,,
Re: OS 20FP manual?
« Reply #5 on: April 24, 2012, 04:21:36 PM »
HI Tim,
BIG Bear
RNMM/AMM
Muah ha ha ha,,, well played Bill, well played H^^
Re: OS 20FP manual?
« Reply #6 on: April 24, 2012, 04:34:10 PM »
Thank you Mark.  I looked on the OS website, and then Googled, but did not find: you possess superior Google-Fu than do I today.
Bill:  ;)
Interesting fuel mix they recommend: 25% castor and no nitro, or 20% castor, 10% nitro.  No mention of synthetics at all.
Offline Geoff Goodworth
Re: OS 20FP manual?
« Reply #7 on: April 24, 2012, 06:02:55 PM »
Also, that is the manual for the steel liner FPs.
The manual for the ABN FPs specifies 75% methanol, 20% castor oil and 5% nitro or 65% methanol, 20% oil and 15% nitro.
Again, no mention of synthetic oil.
The LA manual recommends the same fuels as the ABN FPs.
Re: OS 20FP manual?
« Reply #8 on: April 24, 2012, 06:27:13 PM »
I now use the castor only fuel in old worn out engines that would loose too much compression if synthetic oil was used.  Sig Champion ( 1/2 and 1/2 oil) w/4 oz. of castor added per gallon for the old iron piston bushing crank engines like the Fox .35.
BIG Bear
RNMM/AMM
Re: OS 20FP manual?
« Reply #9 on: April 27, 2012, 10:28:58 AM »
HI Tim,
   Yes, as a matter of fact, it does! It says to take it out of the box, assemble it, and bolt it to the airplane. Nowhere in there does it mention a Dremel tool with a grinding point, nor does it discuss blocking the boost port, putting in a smaller venturi, adding head gaskets, running 11-5.5 props at 8500 rpm in a 4-stroke, throwing away the muffler, etc. It also recommends a 9-4 prop for break-in, and for "sport flying".  It's almost as if OS actually knew how to build a good engine BEFORE they consulted with "stunt experts".
Re: OS 20FP manual?
« Reply #10 on: April 27, 2012, 11:02:15 AM »
How odd.  That an engine manufacturer should know their job.
Re: OS 20FP manual?
« Reply #11 on: June 19, 2012, 04:16:17 PM »
They probably consulted with Brett before finalizing the design!   #^
Re: OS 20FP manual?
« Reply #12 on: June 19, 2012, 05:10:00 PM »
They came pretty close with the VF, too.
Re: OS 20FP manual?
« Reply #13 on: June 19, 2012, 11:28:09 PM »
Yeah...I'll bet they were as surprised as we were about that one!!!   y1
Randy C.
