Engine basics => Engine set up tips => Topic started by: frank mccune on October 29, 2018, 05:46:29 PM
Title: Open face mufflers? How to get them to muffle?
Post by: frank mccune on October 29, 2018, 05:46:29 PM
        Hello All:
        I have a few HP Silver Star .40 engines complete with factory mufflers.  How can I get these open face mufflers to reduce exhaust noise? As  they are, they do not appear to do any good in reducing exhaust noise.  Can I close the front end to reduce the noise?
        Suggestions???????????
        All the best,
        Frank McCune
Title: Re: Open face mufflers? How to get them to muffle?
Post by: Dave Hull on October 29, 2018, 07:46:47 PM
Can you post a picture, Frank? (Is it like the photo attached?)
I think you are talking about an early "flow thru" style muffler. "Open face" is generally meant to describe the engine stack with no muffler installed. If you look in rule books, there are events that require you to run open faced, meaning no tuned pipe, no mini-pipe, and no tuned mufflers. This limits performance when needed.
There is no question that the noise is coming out the front--even in flight. The speed of sound is waaaaay faster than any air coming in the front of your muffler! And looking at the geometry of the picture I found (which may not be the one you have) you practically have a megaphone on the front end.
If you decide to try modifying the muffler, just be careful of making it too restrictive and overheating the engine. I would think you could make it work.
MECOA lists a muffler for the Silver Star: part number 30-2101, but does not show a photo. It may be the same as you have, or it may be a later factory muffler. They appear to be sold out. But they might be out there to be found.
Even a hardwood plug in the front is good enough for a test. JB Weld would hold up for quite a while if you don't cut/sand/trim it. The skin formed during cure seems to provide the fuelproofing.
How big is the muffler exhaust dimension? You will probably have to close this down a bit also--perhaps down into the .350--.310 range once you cap the front.
A nice little project, but if it does not give good results, what other mufflers might fit? Does Randy Smith offer one, ready to go? I understand these engines were used for stunt, so I'm sure someone has found a muffler solution.
Good luck,
Post by: frank mccune on October 30, 2018, 09:47:27 AM
     Hi Dave:
     Thanks for the prompt reply.  Yes, that indeed is the muffler in question.  It is very loud and decreases the noised very little.  As a matter of fact, I can not find any reson to use that muffler except tp increase nose weight. Lol
        Be well,
        Frfank McCune
Post by: GallopingGhostler on October 30, 2018, 11:55:39 AM
I've got a legacy aftermarket Kavan muffler for my Enya .35-V TV. It is venturi style but has slits formed by the larger nose to allow air in. For noise reduction, it came with a quarter (coin) sized milled circular plate that was inserted in the front of the muffler to blank off the slit opening where greater muffling was required. It's weight makes it only suitable for RC.
For yours, it would require closing off the venturi opening up front, but of course anything done might require modifying it, changing its exterior appearance (extra screws, etc.). I'd think one would be better off spending a little and buying a suitable tongue muffler for it.
Post by: M Spencer on October 30, 2018, 05:28:29 PM
That There ' flow thru ' is similar to similar FOX ones .
The fox 19 / 25 / 35 one , came open front & closed front .
THEY , like the HP , have a slotted tube - for baffling . ( Gunna use the little fox ones on a new stack , for 40 schneurles & ST 46 etc . )
(https://thumbs.worthpoint.com/zoom/images1/1/0313/21/vintage-fox-35-muffler-polished_1_594516ca7f2b31aa69ca53a6978d4df0.jpg)
heres a pitcherofa later Gold cup HP muffler .
(https://static.rcgroups.net/forums/attachments/7/4/3/2/8/1/a11268780-71-20181011_003301.jpg)
(https://i.ebayimg.com/images/g/HKwAAOSw-YVXmT~k/s-l300.jpg)
And a OS one . the OS 40 & 45 FSR has the same bolt spacing . BE CAREFULL WITH THE SCREWS >
Lube Them . Carefull starting the screw in . Pain in the ass to strip them . tho the OS's etc are NOW all tapped to 4 B.A. .
Think the IRVINE 40 mufflers the same space too . at least THIS ONE is ,
(https://i.ebayimg.com/images/g/IZkAAOSwLEVblXTi/s-l300.jpg)
removeable Front / case . One was side exit ' quite ' muffler . for quite .
I used 1 1/2 Irvine extensions , for 3/4 inch stack . a piece of 1 in dia alumn toob , 9 ? holes drilled X style ( like tounge muffler )
outer face rearish on th 2 in long tube . Very Hushed - good Powerband . on the HP 40 R P R .
Will  tryn chuck a pitcher on ere . ( long bolts crush the tube - so is a bit battered .
BUNGING THE FRONT of your HP 40 MUFFLER , wont do no harm at all . Rear Outlets still more than adequate . A frost plug , maybe ? .
Shine a flash light through it and observe from the three orrifaces , first . Baffled tube in there .
Post by: Dave Hull on October 30, 2018, 08:31:50 PM
Frank,
Have you tried blocking the muffler air inlet to see if the sound level is acceptable? If the noise level drops to something you can live with, then I would go ahead and modify it and see if you like the way it runs.
Here's a quick way to test it out. Cut two 1/8" plywood disks. One just bigger than the front of the muffler, and one that just barely fits inside. Glue together like a wedding cake. Hold it on by stretching an o-ring from behind the manifold over the front of the plug in the center. Glue on a couple of cleats to the front to keep the o-ring from rolling off. Tune and fly.
Admiral Spencer left a caution that there are internal baffles in this muffler. I couldn't tell that from the outside photos, so altering those may be part of the overall solution. I can't think of a baffle configuration that would require mods for it to work, but if the original muffler had so much back pressure that it actually had to "leak" out the front, then if you block the front, you have to improve flow to the rear.
Also, I am a bit lost regarding the configuration of the Enya and aftermarket mufflers that George discussed. I see no evidence in the photo of air slits or even blocked air inlets. A bit more info would help...?
If you don't want the weight of the stock (or modified) muffler, then a tongue muffler or a Dinger-style can muffler would be a good compromise. It's the All-American choice of farmers:  either fix it yourself for no coin, or pay somebody to fix it. Or buy a bag of earplugs and hand them out to anyone within a 1/4 mile....
Good luck!
Post by: M Spencer on October 31, 2018, 11:22:26 PM
Rough as guts , but a secret weapon wonder muffler . 3 1/2 ( 3/16 caps inside ) x 1 in O.D. 10 x 2 mm or 3/32 Holes .
p.s. Not to sure theres a tube inside the HP thru flow, thinking about it , now , Dave . Easy to see inside with a Flashlight tho .
