Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
July 03, 2025, 03:10:47 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
Older Max-S question
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Older Max-S question (Read 1241 times)
rich gorrill
23 supporter
Trade Count:
0
Commander
on:
February 04, 2015, 04:18:05 AM »
Quick question about Max=S 35 with a carb. Will the newer venturi's for the L.A. and F.P. fit to convert to control line. Also will the newer needle's work.
T.I.A.
Rich
Logged
Bill Little
2017
Trade Count:
0
Admiral
Second in COMMAND
Re: Older Max-S question
Reply #1 on:
February 04, 2015, 09:33:33 AM »
Hi Rich,
No, you will have to get one made for the "S". The newer NVA also has a smaller OD. Several sources for a venturi, check the Vendor's Corner. I know Randy Smith and Jim Lee both supply then.
BIG Bear
RNMM/AMM
Logged
Big Bear
AMA 95351 (got one of my old numbers back!
rich gorrill
23 supporter
Trade Count:
0
Commander
Reply #2 on:
February 04, 2015, 04:03:29 PM »
Thanks Bill
Logged
M Spencer
Trade Count:
0
Admiral
Reply #3 on:
February 04, 2015, 09:31:44 PM »
The Olde OS max 20 & 25 venturie fit , they ( sometimes ) came with THREE . Bigger ones just smaller than std. .35 sucker .
SEARCH here gets a bit of info on prefered sizes .
a nice long nylon ones likely to run more even .
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
Jump to:
=> Engine set up tips
