  • July 09, 2025, 01:48:44 AM
Author Topic: Ok SUPER60 SPARKY  (Read 6011 times)
Offline Brad Smith
Ok SUPER60 SPARKY
« on: August 06, 2012, 08:45:38 AM »
I have an OK SUPER 60  i know nothing baout sparky engines what do i need to get this engine running thanks for any info .
Brad smith AMA780054
Offline De Hill
Re: Ok SUPER60 SPARKY
« Reply #1 on: August 06, 2012, 08:57:45 AM »
Hi Brad,
Get ahold of Jim Lee. He has run an OK super .60, and knows what to do to set it up right.
I think he replaced the wrist pin because it is weak.
De Hill
De Hill
« Reply #2 on: August 06, 2012, 11:06:31 AM »
Brad.  If you need help with the spark ignition system/hookup, contact me and I think I can answer any questions.
Floyd Carter
Eugene, OR
Offline Brad Smith
« Reply #3 on: August 06, 2012, 07:17:02 PM »
Floyd all ihave is the engine nothing else i need to what i need to get and where to get it any help thanks
« Reply #4 on: August 06, 2012, 08:46:11 PM »
Jim Kraft makes spark ignition look really easy.  After watching him fly flight after flight, trouble free, with spark ignition engines, I had to try it.  I copied his setup as closely as possible and I've been happy with the results.  Read this page, http://www.modelflight.com/ignition.html.  It'll tell you all you need to know to build a transistorized ignition circuit.  If you can operate a soldering iron, it's a very easy circuit to assemble.  Just follow the diagram and the tips.  The TIP42 transistors can be found at Radio Shack cheap, and they've worked OK for me.  Used Modelectric and Aero Spark coils can be found on Ebay, most of the time.  3 AA or AAA NiMH batteries work well for power.  Running on 5% nitro, 25% all castor fuel, they're almost as easy to deal with as an old glow engine.
In my experience (admittedly rather limited), the "Larry coil" doesn't work.  The same applies to vintage spark plugs.  They work great until the electrode pulls out of the insulator.  It's easier just to start with a new plug.
As mentioned, OK engines are of varying quality.  Sometimes you can have one with great compression, that runs great, others don't or hardly run at all.  I've got an OK Super 60 that runs great on the test stand, and I'm still cautious to build a nice plane for it.  I'd run the engine more than a few times on the test stand before building a plane specifically for it.
Offline De Hill
« Reply #5 on: August 06, 2012, 09:05:04 PM »
Bob Zambelli is another modeler who has successfully ran an OK Super .60. He would also know a lot about that engine.
De Hill
Offline Andrew Tinsley
« Reply #6 on: August 07, 2012, 05:12:59 AM »
Hello Brad,
I have quite a few OK 60s and They all seem to run extremely well. If you want to know how to run them in the old style (no transistorisedignition). Look up some past posts by Bob Zambelli. he runs them in the traditional manner with petrol oil mix and has them well sorted. Flloyd Carter is the man for transistorised ignition and both of the above gentleman have given me lots of information and tips via PM's. Contact them for a really in depth help session! I can't praise them enough for the help they gave me.
  Looking at some of the other responses, there are one or two points to be aware of. My Super 60s have good compression and start easily by hand. I know of (and have seen) others with much worse compression, that are difficult to handstart. All of the latter will start very easily with an electric starter. I believe that many Super 60s were used in tether car racing, back in the day and some form of starter was invariably used to get them going. The downside of this is that the bearings are fine, but many Super 60s seem to be made with a weak wrist pin (some sort of bronze?). All of my examples are fitted with steel wrist pins. I don't know if OK did this at some stage or if it is an aftermarket conversion. I have never seen anything but steel in this area and I have seven of the OK engines (did I say I liked them?). Any feedback on this would be welcome as I have never been able to work out what was going on here.
  The comments on old plugs are a little harsh. In my experience of sparkies, old Champion plugs are a pain, with the center electrode blowing out. Other makes have not had this problem. Modern plugs are well made in this respect, although performance can be down on some of the old plugs, much to my surprise.
  About the only available new coils are the Larry Davidson ones, which are a literal Chinese copy of a well known US make of a few years ago (memory not working!). These coils are fine in a traditional setup, but can give huge problems when used with transistorised ignition. Normally they simply don't work, at the risk of Larry suing me. Flloyd told me that the main problem was that the TIP42 transistor had a very low reverse breakdown voltage. He recommended a type with a much higher reverse breakdown. I tried these transistors and although some Larry coils then worked, others did not. Still you can buy them and still use them in non transistor ignition circuits and there they have given me no problems whatsoever, just be careful if you go the transistorised route!
  I have not checked the RPM of my engines, but I guess they run at between 6 to 7 thousand RPM. At these revs, they do vibrate much more than modern engines. Don Howie, in Australia, says that with the right prop (I think it was an APC of about 13x6 or 7). The engine gets past this vibration region and smooths out. Unfortunately at higher revs, the integrity of the engine becomes suspect. I have managed to destroy one at these sort of higher revs, so be warned!
  About the only real problem with the OK and other similar sized sparkies is the noise! If you run on petrol then a normal expansion type muffler will get the engine very hot. That is about the only reason that I run on castor / methanol brew, they do run cooler on such fuel. A tongue muffler can easily be fabricated for a Super 60, but it doesn't do much muffling and in the UK, noise is bad news. I have copied Bob Zambelli's idea of fitting a very long, large volume expansion exhaust fitted to the fuselage, with the exhaust stack fitting into a slit. A little high temp RTV does a poor sealing function and the noise is then acceptable.
  I have been running sparkies in stunt aircraft for a few years now and it is great fun, I am still learning, so any comments or feedback are most welcome.
Andrew.
BMFA Number 64862
« Reply #7 on: August 07, 2012, 10:06:46 AM »
Gentlemen.  I have thoroughly tested Larry Davidson's Chinese-made spark coils.  They are an EXACT copy of the Gettig coil made in USA.  I find them to be very good.  Although some try to run them on Alkaline cells, they work best with 3 NiCd of 1000MAH or higher, (3.6 V), or else a LiPo cell (3.7 V).
I'm sure Larry and I would like to hear the exact details about any failures, instead of "they don't work."
Floyd Carter
« Reply #8 on: August 07, 2012, 11:21:28 AM »
Hello Floyd,
Apologies for misspelling your name. Re Larry Davidson copies of the Getttig coils. I have tried several without transistorised ignition and they are excellent coils and lightweight to boot. I first came across these coils several years ago. and didn't realise from whence they came. They looked like the Gettig coil dimensionally, but obviously were not. I was approached by two people in quick succession that were trying to run them from the simple TIP42 type circuits. Apart from an occasional pop and bang, this set up didn't work. I swopped the coil out for a known good one and all was well. My memory may be at fault here, but I thought that I discussed the problem with you via email (apologies if it were someone else). The recommendation was to use a transistor with a higher reverse breakdown voltage. I obtained a dozen of the recommended transistors from a specialist dealer in old transistor types and built a version of your TIM 4 ignition unit. The first two Larry coils then ran well with this set up. I have had one further example of the Larry coil through my hands and this one ran with the TIM 4 circuit, although it was missing quite a bit.
  To summarise, there does seem to be a problem with some coils in some transistorised circuits. I have seen other Larry Davidson coils run very well indeed with simple TIP 42 circuits!
  I have enough old coils to keep me going for years, so I have not purchased any of Larry Davidson's coils myself. The ones that I have experience of, had been run for very lengthy periods when trying to start the engines. It could well be that the people involved ( they had zero knowledge of sparkies) had overheated the coils during this process. The lack of starting could have been down to inexperience or something else not being correct. I am simply reporting what I have observed. I can see no reason why the Chinese made coils should be any different from the original Gettig coil, they do run extremely well in conventional non transistorised form. so I am unsure why I have seen problems. I have tried to analyse the problem and have used a high voltage probe and a storage scope to take a look at the wave forms involved, without being able to come to any conclusion. The coils work without the transistorised circuit, some coils don't work with a transistorised circuits and these same circuits work with other makes of coil!!!!!!!!
  I don't want to get into any arguments, something odd is going on and I wouldn't mind knowing what that is. I think that Larry Davidson should be commended for taking the trouble of supplying an inexpensive lightweight coil and I would not wish to say otherwise. I believe that the reverse breakdown voltage of the power transistor would be the most likely explanation as you (?) suggested.
Andrew.
BMFA Number 64862
« Reply #9 on: August 07, 2012, 07:38:30 PM »
Floyd Carter
With all due respect, Floyd, we've already discussed this.  http://stunthanger.com/smf/index.php?topic=11420.0  I can't really say much more than I did last time.
At the time, I contacted Larry Davidson.  His reply was that he was aware his coil doesn't work with the circuit shown on modelflight.com.  His recommendation was that I buy his/your(?) transistorized ignition system.  Since that was already after I'd swapped the Larry coil in my circuit for a used Aero Spark coil, which instantly cured all the problems I was having, I didn't pursue that option.  I've since made up at least 3 more circuits like the first one, always using the Aero Spark or Modelectric coils, and they all work great.
While the Larry coil may very well work with different batteries, or a different transistor, that issue is moot to me.  For the $54 current price of the Larry coil, and TIM4 ignition, I can buy two used Aero Spark coils on Ebay.  The parts I use for my ignition systems cost me about $5 each at Radio Shack.  It's more economical for me to keep using what I've been using, because it works for me.
The only reason I mentioned the problem I had, was to save someone else the frustration.  Since the modelflight website links to and recommends Larry's parts, I wouldn't feel right not warning someone that the combination of that circuit and his coils is no good.  My apologies to Larry Davidson for saying bad things about his product, but seeing as how he's known there's a problem since at least 2007 (when I emailed him and he explained he already knew), it's really his own fault.
Offline Robert Zambelli
« Reply #10 on: August 08, 2012, 02:30:22 AM »
Hello, Gents.
I too favor the OK Super 60 for a number of reasons. It is very reliable, easy to start, fairly light and quite reasonably priced. I've sold a few brand new ones on eBay for right around $100.00.
There are a few mods that are easy to accomplish and, in my opinion, really help the overall performance.
1) The original bronze wrist pin should be replaced. I have seen instances where they actually flex, causing the bosses inside the piston to fracture.
2) I remove ALL gaskets and substitute Loctite Anaerobic Gasket Eliminator, item number 51817.
3) I use a Super Tiger needle valve assembly.
4) I used 6-32 Allen cap screws for cylinder hold-down and backplate attachment.
5) I reverse the exhaust to where it points outside the circle.
When I first started using the S-60, I noticed that the points looked very familiar. Turns out, they are identical to those on my 1967 ALFA Romeo. Only the pivot bushing has to be reamed a bit to .189.
Regarding the muffler that Andrew mentioned, I am really pleased with the results. Being of substantial volume, it allows the exhaust to expand a bit, therefore dissipating some of the energy before exiting. Some high temperature RTV seals it well. Note that it is mounted to the airframe, not the engine.
As far as ignition goes, I have used only the standard points/coil/condenser/battery combination with perfect results. I understand that Floyd's transistorized system is excellent and many people favor it over my setup.
Spark plugs: I have had TERRIBLE results with Champion plugs. My preference is the AC - hundreds of flights and I only clean it once a year.
I've had the best results with some old Top-Flite 12-8 wooden props.
75% premium gasoline, 25% castor oil and a touch of nitrobenzine.
I will be submitting an article in the next CL World describing the fitment of the muffler to the OK S-60.
I hope this helps.
« Reply #11 on: August 10, 2012, 12:46:01 PM »
Gentlemen.  I fail to see any connection between "problems" with Larry's coils made in China and the transistor driver. All that the transistor does is eliminate the high current (4 1/2 Amperes) flowing through the ignition point system, which is prone to resistance build-up due to metal-to-metal sliding fits, and oil on contact surfaces.  The maximum voltage drop (loss) through the transistor is less than 0.1 volt.  That means that, with 3 NiCd cells at 3.6 volts, the coil "sees" 3.5 volts.  The Gettig,Chinese coil will certainly perform at 3.5 volts.
It's pretty easy for the Chinese to copy exactly the Gettig coils, including exact materals, wire and turns.  All the Larry's coils I have used worked flawlessly on 3 NiCd cells or a single LiPo cell.  I don't use a "booster" for starting.
The TIP42 transistors that were once popular are not quite up to the task.  I now use Motorola BD244, a PNP in the same package.  They always work.
I have provided Larry with hundreds of TIM-4 transistor modules.  They are universally used by the free flight people.  Not a single one has come back for warranty repair, and Larry has not sent any complaints to me about the TIM-4 running on his coils.
I assume that everyone uses NiCd cells, or LiPo.  alkaline cells only cause grief!
I'm still looking for specific complaints regarding the Larry coil.  And if anyone wihes to send me one of Larry's coils that will not work, I will be happy to give it a thorough test and send it back with a complete report.
« Reply #12 on: August 10, 2012, 02:48:52 PM »
Floyd,
All of the Larry Davidson coils I have had through my hands have always worked, without a transistorised switching circuit. The problem arises with some transistorised switching circuits. They simply WILL NOT drive a Larry Davidson Coil. Other circuits WILL drive the same coil. You can take ANY of the transistor switching circuits which WILL NOT drive the Larry Davidson coil and try them on ANY other make of coil and the system will perform. I have had one TIM4 circuit (your original manufacture) which would only drive a particular Larry Davidson coil with lots of miss firing. The same TIM4 circuit drove any of my other coils flawlessly.
  I have used DB244 transistors in my own brew circuits and have never had a problem driving anything. I have also seen the standard TIP42 circuit, drive a Larry Davidson coil.
  There is NO doubt that the Larry Davidson coil will not function with some transistor drivers. This has been noted by two Australian friends, who have been flying ignition since the late 1940s, by myself, by Andrew Hathaway and indeed by Larry Davidson himself. If Larry Davidson admits there is a problem, it seems odd that you should deny that there is.
  I simply avoid the problem by using other makes of coil, including some that I have wound myself. It has been maybe two years since I saw these problems. The problem is real and I still cannot figure out what is the cause. Reverse breakdown voltage of the power transitor is favourite. But these self same transistors don't breakdown with other types of coil.
  I suppose that we shall not be able to agree on this aspect of Mr Davidson's coils. For those that do experience this odd behaviour, simply do away with the transistorised ignition, save a few grams weight and enjoy them as they used to work, back in the 1940s. Used like this, they do work very well indeed, as good, if not better than the old coils!
Andrew.
BMFA Number 64862
« Reply #13 on: August 10, 2012, 06:14:15 PM »
I agree Andrew Tinsley. I was in on the testing of the Larry coil with Andrew Hathaway, and we had the same thing as you. The Larry coil would not work with the transistor that Andrew H. was using, and we changed to an old Aerospark coil and it worked fine. We tried several times back and forth with the same results. That is when Larry told Andrew that his coil would not work with the transistor he was using. I have never tried it with a condenser set up. I imagine they work just fine with Larry's transistor driver and his coil in a free flight where they only run a short time. Most of the old coils if they are still electrically OK work very well. I have one old large Aerospark coil that is around 6500 ohms from primary to secondary, and it will throw a spark a 1/2" on three AA NIMH batteries and a single transistor. I had to repair one of the primary leads on it about 10 years ago, and it has been flown many times since then. I use VOM lead wire for my hi tension lead to the to keep from getting zapped if I get my hand close to the wire.
« Reply #14 on: August 12, 2012, 01:21:42 PM »
I agree that the large Aero Spark coils are awesome!  However, they weigh 2 oz.  They were intended for tether cars where weight isn't a factor.
The Gettig and the Larry coils are under 1 oz.  They provide adequate spark, but not excessive.
I repeat my offer to test and analyze any Larry coil for you which is suspect.  I have yet to find a bad one.  Larry D. is a good and honest guy, but he doesn't have the test equipment, or the expertise, to diagnose a bad coil.  I do.
« Reply #15 on: August 13, 2012, 02:24:34 AM »
Hello Floyd,
I have never possessed a Larry coil, the ones that passed through my hands were those belonging to people that had the problems. that was two years ago and sadly I don't suppose that I will be able to retrieve the coils that gave the odd results. I shall try, but don't hold your breath! Just for the record. The problem that I saw was an incompatibility of some transistor drivers and Larry's coil. All the coils that passed through my hands (and those in OZ) would work perfectly in traditional mode and with different transistor drivers.
  I suspect that some coils were prone to this odd behaviour (probably not all). I emphasise that it was and is, an incompatibility problem. Both coil and driver would work happily if paired with other coils and drivers! It is NOT a case of the coil not working, but of a particular coil / driver combination. How common the problem is I don't know. Larry Davidson sells mainly to the free flight guys and I suspect that if they want transistorised ignition , they would buy a TIM 4 or similar driver from Larry.  That combination seems always to work. It is only odd balls like myself and other C/L and vintage types that build their own driver circuits. If I can retrieve a coil and driver that displays the problem, I will send it off to you to see what you make of it. Even with good diagnostic gear, I found myself going round in circles and failed to get to the bottom of it!
Andrew.
BMFA Number 64862
« Reply #16 on: August 13, 2012, 01:29:37 PM »
Once again, the transistor driver is nothing more than a switch.  As long as the driver doesn't suffer from "secondary breakdown" (transistor voltage rating not high enough), charge storage (slowing the turn-off), and the "on" voltage drop across the transistor isn't excessive, then the coil has no way of knowing where its drive current came from!  The primary DC resistance of Larry's coils is 0.8 Ohm, the same as Gettig, Modelectric, etc.  Inductance might be a bit lower because the small coils have less iron in their core.  But this would not make some of them good and some bad because the core material is always the same.
I have no dog in this hunt.  I stand to gain or lose nothing by it.  I am only curious and wish to solve the problem, if one exists.
I have provided transistor coil drivers since 1980, as Aero Ply Research Co.  I started with capacitor-discharge units, then went to the simpler switching transistor circuit.  I still supply Larry Davidson with the TIM-4 driver, at about 30 per year, depending on his sales picture.
« Reply #17 on: August 14, 2012, 10:44:23 AM »
Hello Floyd,
I don't disagree with any of your analysis. Which makes me as mystified as you. I only got involved because people asked me what was going on. So the first thing is that I have been fed with problem combinations. How common the problem is, in reality, is hard to say. Certainly two or three people have seen the same puzzling behaviour. You could swop coils and transistor switches any number of times and the results were perfectly reproducible. At the time, I had no idea from whence the coils came, so I most certainly have no axe to grind one way or the other. My only interest is to understand what is going on. I am trying to contact one of the people that came to me so that I can get my hands a problem coil. It is a long shot, because I don't really know the person at all well and I have a suspicion he has since moved house. If I can get hold of the coil, I still have the two drivers in my possession and I will get them off to you.
  Maybe Andrew Hathaway still has the combination that gave him the same problem? It is worth trying to nail this one to the ground, because it is one of the most puzzling things that I have come across in a very long time.
Andrew.
BMFA Number 64862
« Reply #18 on: August 14, 2012, 01:20:26 PM »
From my point of view, there are already a few viable workarounds for this problem.  I don't really see a need to find more solutions.  I don't have an axe to grind either, my intention was only to recommend what's worked for me, and point out a couple potential pitfalls.  The Larry coil I had never did much more than the occasional pop, except for dripping melted wax, and eventually the high tension lead terminal fell off.  Between being obviously damaged, and either lost in the shop or long since tossed in the garbage, it's just not worth messing with.
The Aerospark "Featherweight" coils I use, weigh 1.25oz and work great.  I can't see a .5oz being a major concern on a 50oz .60 size plane.  There's more potential in weight savings by using different batteries or a different engine.  The only real advantage I see to the Larry coil is that it's available, but I'd gladly trade availability and the weight savings, for a more dependable coil.
Offline Jim Bode
« Reply #19 on: January 09, 2019, 07:00:55 AM »
Hello Bob Z.
5) I reverse the exhaust to where it points outside the circle.   by Bob Z.
Replying to a rather old post   here - I had an Super 60 around 1954 but it was lost in a fire.   I recently acquired several S 60s in fair condition and I like to bring them up to running condition.
I have a couple questions about your suggested improvements.
1.  What did you use to replace the wrist pins and did you pad the ends ?
2.  I have a Super Tiger needle valve labeled for a 60.  Is that the one you use?   One of my S 60s has a bent needle valve tube.   Bent a little in the threads  so I expect it will break if I straighten it so a good candidate for the ST needle.
Offline Dave Moritz
« Reply #20 on: January 09, 2019, 03:10:42 PM »
Andrew T:
I'm curious about your use of a long expansion exhaust for the OK 60 to reduce noise. I would like your comments here, if you'd be so kind.
I've got an Ohlsson 60 (the 1941 version) that needs to run on petrol and caster only - thus it really does bark. Given the noise level, I've confined it to short bench runs. The advice I've heard so far is that any kind of muffler would cause problems with heat and reduced power. I really don't want to build and fly something for it without reducing the noise a bit. Might have to look into the approach you've suggested to see if it has any merits for this motor.
Thanks.
Dave Mo...
« Reply #21 on: January 09, 2019, 05:13:07 PM »
I modified a Fox stunt tongue muffler to fit my Super Cyclones. I opened the holes some and it works OK, but still plenty loud. It does take the sharp bark out of it. If I was going to do another, I would leave the holes the same size and add another row of holes.
I run Camp stove fuel and Walmart Super Tech 2 standard 2 stroke oil which runs a lot cooler than 70wt or castor. But I still like to run them open exhaust.
Tags: ok super 60 mods
