Hi guys,
I've run the RoJett 61 on the bench for an hour, really needs to run somemore. I've run her off of the tank I made for her. I've had her in the SV11 about a million times. The plane is ready, the tank is done, the engine is close. The only problem is me, I have to add weight to the nose. Darn 61 is to lite?? My OS Max 46 VF is due in today, maybe should wait and fly the SV 11 with the VF first?? I'm sure the VF weighs more than the beautiful Brett 61. I want to be sure the plane will fly okay before trying the pretty 61?? I checked all the bench trim items?
Looks okay, had to re-shrink the covering again??? The plane lives on my patio and it does get warm, so maybe a good thing??? The plane complete weighs 61 big ounces?
I cheated I didn't install a pipe support, I just drilled a hole thru the back mount, behind the wing, and put a zip tie thru and locked her down??? Yes, I formed it to match the pipe curve?
Tomorrow, Tomorrow, always tomorrow!!!
Gary
