  • June 21, 2025, 08:08:12 PM
Author Topic: Can I use OS Max NVA for 20-40 engines (OS PN 22311000) for 60-76 engines  (Read 1146 times)
Offline Matt Piatkowski
Hello,
I believe the answer is YES if larger ID venturi is used.
Your comments and suggestions will be appreciated.
Thank you,
Matt
Offline Geoff Goodworth
That NVA is 3.5mm dia and the boss that it fits in is 15mm wide.
If that suits your larger engines, it should work. If you need a larger diameter NVA, the Enya and ST parts are 4mm dia. Randy Smith can supply either.
Hello,
Thank you,
Matt
depends on which engine your talking about
