  • July 10, 2025, 07:28:02 PM
Author Topic: OK Cub .049  (Read 2800 times)
Offline Phil Bare
OK Cub .049
« on: October 16, 2019, 04:13:36 PM »
This Is probably posted in the wrong place, but here goes anyway.
I am in need of a needle valve for an OK Cub .049.
Any one have one that I can buy let me know.
my email is flbare@skybest.com
Offline Carl Cisneros
Carl R Cisneros, Dist IV
Control Line RB
Offline Robert Whitley
Re: OK Cub .049
« Reply #3 on: October 17, 2019, 07:29:42 PM »
If you contact OK Cub directly they might be able to supply the parts you need.
They have discontinued engine manufacture but still advertise service and some parts availability.
I bought a last edition commemorative engine and some parts a few years ago and the pricing and service was second to none.
Offline Peter in Fairfax, VA
Re: OK Cub .049
« Reply #4 on: October 20, 2019, 02:50:09 PM »
Had no idea the OK business was still going.
Link: http://www.okengines.com/museum.shtml
Offline Phil Bare
Re: OK Cub .049
« Reply #5 on: October 20, 2019, 03:44:24 PM »
Can not seem to contact them.                             Phil Bare
Offline YakNine
Re: OK Cub .049
« Reply #6 on: December 28, 2019, 08:07:33 PM »
I bought a bunch of parts from Ted last year and sent him 2 crash damaged engines that I held onto for years for sentimental reasons, or maybe because I'm a packrat :) , for $15.00 each he replaced all the broken parts and sent them back running again, I also bought an extra .049A. A great guy to deal with. TJ
AMA 85135        GSCB
Offline Oldenginerod
Re: OK Cub .049
« Reply #7 on: December 28, 2019, 10:03:57 PM »
You might do better with the Kap-Pak type needle as shown in the ebay listing.  I would probably have more taper on it than the original.  Even the latest needle from OK was way too blunt, making them over-sensitive.  Some suggest that you need to file more taper on them, but I've found that it doesn't take too much extra taper to make the thimble bottom-out, not allowing the needle to fully close.
As has been said, I believe you can still get many parts directly out of OK Engines.  The needles they currently (or most recently) sell are different to the original in that they have a spring rather than a split thimble.  Depends if you want it to display as original or you need it to function better.
Rod.
