Engine basics => Engine set up tips => Topic started by: Terry Caron on March 17, 2015, 02:51:07 PM
Am I correct in thinking some of the old OK .29 or .35 had a ball and socket rod/piston assy?
Thanks.
Terry
Hi, Terry.
Every OK engine I've owned had a standard wrist pin piston assembly.
Here's a pic of it - any idea what it's for?
Terry
I know that there were a few engines in that size class that used a ball & socket "wrist joint". To the extent of my scant knowledge, this technique enjoyed a short surge of popularity right after WW-II. There's no way I could even guess what engine your con rod might go to, however.
Possibly Mohawk?
I know nothing about them other than that they exist, but I think were also an early Herkimer product.
Terry
The Mohawk .29 is just the early OK .29 with some cosmetic changes to the case, and no main bearing. The rod is/was a typical piece with a normal wrist pin.
That's not a Mohawk part.
Well, rats!
I'm sure someone could use this, if I could find out what it's for.
Just in case:
OAL 1.722"
Crankpin ID .218"
" width .214"
Ball diam .209"
Terry
P.S. - just found that I also have 2 unfinished .29 Mohawk con rod rough castings, typical as you said Andrew, PM if anyone could use one.
And a finished .29 Cub rod.
I could use the Mohawk 29 rods. OK's idea of finishing the rod is to cut 90% of the way through the crank pin hole with a hacksaw for lubrication. I think I've got about a dozen OK and Mohawk 29s, but I'm short a few rods since they like to crack at the saw cut. I've been meaning to order a few of the castings from OK, but I'm pretty sure the last catalog I received from them was dated 2011. n~
