  • June 20, 2025, 12:01:27 AM
Author Topic: OK .099 needle valve  (Read 916 times)
Offline Mike Scholtes
« on: November 28, 2017, 10:08:09 PM »
Okay this is really obscure, but I bet someone on here can answer this one. I just obtained an OK .099 that appears to be in excellent condition. The needle valve however ends with a fairly squared-off tip, not a "needle" shape. It may be reduced in diameter slightly at the tip. So, is this normal, or should the needle have a pointed end? I can post a picture if cell phone camera will cooperate. I intend to fly this so want to make run properly.
Offline kenneth cook
Re: OK .099 needle valve
« Reply #1 on: November 30, 2017, 03:02:47 AM »
             Mike, the needle valves on the OK engines are quite crude. There's not really much of a taper and as you mentioned just a rounded end. I have seen some examples where a Cox spraybar has been removed from a production backplate and JB weld was used to retain it in the case. The stock example works however it's very short placing your fingers in close proximity of the prop. Perfect made a replacement needle with a spring between the needle and the knob which in fact does utilize a taper that fits the OK spraybars if you can locate on it's a direct replacement.
« Reply #2 on: November 30, 2017, 01:05:47 PM »
Thanks Kenneth, I was sure somebody would have the answer! I may look for a small NVA assembly to replace the stock one. I noted the finger-slicing location of the needle (or "stub" more accurately) and prefer to keep my blood on the inside. Finding a Perfect brand replacement is probably a needle in a haystack thing but who knows.
« Reply #3 on: December 04, 2017, 05:01:13 PM »
Under magnification the end of the "needle" does have a blunt taper and reduces slightly in diameter, so it appears to be stock and not broken.
Now that that is resolved, what FUEL is this oldie going to require? Can it be run on modern CL fuel with 22% oil, half castor half synthetic? I have a can of ancient Cox fuel, unopened, that would probably work but not sure. Any help would be appreciated, I have never run an OK engine.
