  • June 26, 2025, 12:29:24 AM
Author Topic: Oil content for an O.S. .35 Stunt with a chromed cylinder?  (Read 2240 times)
Offline frank mccune
« on: June 28, 2023, 10:50:09 AM »
      Hello:
       What oil mix should I use in the above engine.?
        Tia,
         Frank
Online Dave Hull
Re: Oil content for an O.S. .35 Stunt with a chromed cylinder?
« Reply #1 on: June 28, 2023, 03:53:30 PM »
Frank,
Engine type/construction isn't fully defined. Are we to guess that this is an old OS .35S with a Gardiner piston/liner? Or? What is the rest of the construction:
Piston material?
Ringed or lapped?
Liner material?
Rod bushed or not?
Plain or ball-bearing supported crank?
It all matters....
« Reply #2 on: June 28, 2023, 04:15:01 PM »
1/2 castor, 1/2 Klotz Original Techniplate KL205. 20% total oil with 10% nitro, works in almost everything.
« Last Edit: June 30, 2023, 08:39:46 AM by Motorman »
« Reply #3 on: June 30, 2023, 08:18:34 AM »
      What total % should I use.  Can the engine get by  with less oil?
      Tia,
      Frank
« Reply #4 on: June 30, 2023, 08:25:29 AM »
      Tia,
      Frank
   You haven't filled in the other blanks, See Dave Hulls response to your original post.
« Reply #5 on: July 01, 2023, 02:44:51 PM »
We are familiar with the OS .35S (Stunt), but we don't know if it's the OEM piston/cylinder that's been chromed, or the B.G. ABC conversion.
To me, the rod and lower end still require a good amount of oil, with at least half being castor. If there is a problem with varnish buildup, I'd add more Klotz. I'd start with 25% oil for a fresh engine and reduce it to 22% after it has enough time on it...15% castor & 10% Klotz to start, then 15%/7%. Scrubbing bubbles cleans the goop off. Take lots of paper towels along!  D>K Steve
« Reply #6 on: July 02, 2023, 11:32:01 AM »
     Thanks Steve:
      That is the information that I was seeking.
      I was always curious to know what percentage of synthetic oil do I need to keep an engine “clean.”
      Frank
« Reply #7 on: July 19, 2023, 11:32:52 PM »
     Thanks Steve:
      Frank
When in doubt, ALWAYS refer to Randy Smith's pinned articles at the top of this forum. If the answer you need isn't there, it will be a rare situation. I wouldn't claim that 7% Klotz would prevent varnishing from castor oil, but it will help. And I haven't ever had any problems with internal varnishing, and not even much from external crust buildup.
My usual fuel choice is Powermaster 10/22, mostly because the R/C bods won't buy 5/22, so nobody ever stocked it. More nitro, better idle (maybe) because the glowplug will stay hotter (maybe). Either that, or the LHS guys push the more expensive 10% and know that "better idle" is going to impress the typical R/C bod. Basically, see what works for you, keeping in mind that too much oil isn't going to hurt your engine in any permanent way.  D>K Steve
