Thanks, I very much appreciate your interest Steve
, and yes, Eric lists a 9-6.
I noticed fuel leaks on the head when running it today, and when the head bolts wouldn't tighten, I decided I'd take a chance.
Pulling the head, the gasket, stuck inside the groove, came off the cylinder w/o damage and I found what appeared to be carbon build-up on the piston and cylinder gasket seating ring.
A careful examination of the mounting lugs also revealed thread marks in the holes, though nothing shows on the lug surfaces, so it certainly has a past.
I cleaned everything, discovered that a spare McCoy .35 RH gasket was a near-perfect fit over the Forster gasket and reassembled it.
No more crackle, no more leaks.
I don't know how it'd perform in the air, but with the 9-6 on the 4-2 edge at ~9900 rpm, it breaks to ~11.1K in 2-stroke mode.
And Rats! Smoothie is top of my all-time favorites.
Terry
