  • June 17, 2025, 05:00:49 AM
Author Topic: OS Max look-alike muffler  (Read 1092 times)
Offline Joe Ed Pederson
« on: August 04, 2019, 05:09:07 PM »
I bought a .40 LA off ebay and it came with a muffler that looks exactly like the OS Max E-3030, but doesn't have the "OS" emblem or "E-3030" stamped on it.  I took the muffler apart and the front part of the muffler is empty.  The back part has a plate where the front and rear of the muffler come together.  This back plate has a hole in the center about the diameter of the exhaust exit at the rear of the muffler.
Is this muffler a full equivalent of the E-3030, or should I order an E-3030 to replace it?
Joe Ed Pederson
Re: OS Max look-alike muffler
« Reply #1 on: August 04, 2019, 08:42:41 PM »
 could by THREE just in case you break one !.
For #^%* sake , its justa muffla . The TOWER HOBBIES ones are LIGHTER . AND the Motor is REAL A.B.C.
So better value to get the whole caboodle there , if you like being awkward .
Generally said the Radio Mufflers , at least on the FPs , being Bigger , are the better option. Or necesity .
Sorry the Tower Comments on the F P thingo .  Theres a big bad ' List your LA 46 set up ' thread . Maybe at the top off the page here .   H^^
« Reply #2 on: August 05, 2019, 12:07:45 PM »
Thanks, Matt.   Early this morning it occurred to me that the unmarked muffler might be from the Tower Hobbies .40.  Your response seems to confirm that the unmarked muffler was from a Tower .40.
Just did a search of "Tower 40 muffler" and found a post by Tim Wescott in which he indicates his OS .46 LAs run the same on both mufflers.  When I asked about whether the two mufflers were equivalent, I was wanting to know if the motor would run the same on both mufflers.  Tim also indicated  that if he needs more nose weight he uses the E-3030 and the Tower Hobbies muffler if he needs less nose weight.
Joe Ed Pederson
