Someone posted a while back looking to remove the Blue from an OS LA motor. Well I accidently found that "Valvoline Heavy Duty Carb and Throttle Body cleaner" in the spray can softens / removes the blue collor.
I was using it to flush the little chips out of the venturi throat before I pulled the tissue plugging the hole, after drilling it for a ST needle. Sprayed it on the outside to wash some grime off, wiped with a rag and the blue started coming off. Nooks and corners I used a soft brass brush on.
