  • July 16, 2025, 03:48:09 PM
Author Topic: O.S. Head screw size?  (Read 2081 times)
« on: December 16, 2010, 11:21:19 PM »
 What size and thread are the head screws for an O.S..35-S? There is apparently at least two generations or versions of the .35-S. I believe the one in question here would be the last version before the FP series. The originals are phillips head and I'm trying to find socket head replacements for a couple engines.
 Thanks!
Offline Bill Hummel
Re: O.S. Head screw size?
« Reply #1 on: December 17, 2010, 07:19:40 AM »
We buy from Micro Fasteners in NJ, the M3 X .6 x 12mm socket heads.  These seem to fit MOST of the 35-S engines. They started carrying this odd
size a year or so ago.  Just need to cut down the length for the rear cover screws, as only the 12 mm size is available. Good people to deal with!
ama 72090
« Reply #2 on: December 17, 2010, 08:53:21 AM »
Hi Wayne,
Just an FYI:  Dick Byron sells sets of head and back plate socket head screws to use in the OS .35S  Very reasonable price!  I have used several of those sets, w/ no problems.
« Reply #3 on: December 17, 2010, 07:32:12 PM »
 Bill and Bill,
 Yes, I've had great service from Micro Fasteners, excellent supplier. I'll spare the details here, but Dick Byron can keep whatever he might have.
 Thanks! H^^
« Reply #4 on: January 01, 2011, 06:01:57 PM »
 Bill,
 I'm not having luck anywhere else so I think I'm going to get some of these from Micro Fasteners. I found a thread gauge and these are indeed 3x .6mm thread. Apparently .6mm thread is an oddball size. These original head screws are 10mm long. Do you happen to know if the 12mm will have to be shortened so they won't bottom out before the head gets tight?
 Wayne
Offline Bill Hummel
« Reply #5 on: January 01, 2011, 06:09:16 PM »
Hi, Wayne, really difficult size to find; I use the 12mm for the head as they come, and shorten the ones for the backplate.  I think you will be satisfied with the Micro Fastener items.
ama 72090
Online Paul Taylor
« Reply #6 on: January 01, 2011, 06:35:38 PM »
Not sure where I found this but I saved it and ran across it a few days ago. I think it belongs in this thread.
M2.5 x 0.45 and M2.6 x 0.45 Pet-111, 10FSR, 10-25FP
M2.6 x 0.45 Max-10, 15, 20, 25
M2.8 x 0.6 (specially made for OS) Max-1, 11, 111-15, Max-19
M3.0 x 0.5 all SHCS in 3mm sizes
M3.0 x 0.6 Max-S30, S35. Max-H 29, 35, 40
M3.5 x 0.6 Max-H 60, 60-61 FSR
1/8"x40 Max-1, 11, 111-29, 35. 50, 58
« Reply #7 on: January 01, 2011, 07:29:34 PM »
 I think I'll give 'em a whirl. I agree, I've always been satisfied with stuff from Micro Fasteners.
« Reply #8 on: January 09, 2011, 08:48:40 AM »
 Hi Bill,
 I just recieved some of the alloy 3x.6x12mm allen screws from Micro Fasteners. They fit perfectly, but they do bottom out. So, like you said, they will have to be shortened just a bit.
 Thanks! H^^
