Brett, can you suggest a reason why the 6.5mm venturi is right for the FP 20 but marginally too big for the 25 which is 20% larger displacement?
Also, can you suggest an ideal ID for the FP 25?
See the other thread for the full answer. But who ever said there was a direct relationship between the displacement and the venturi size?
The correct (as defined as WC-winning) venturi for a PA75 has less choke area than the 20FP, 40VF, PA61, or RO-Jett 61. I am currently running a #5 AWG venturi with a spigot in the RO-Jett and David ran something like a #13 with a spigot to win the WC - WAY less choke area.
To first approximation, for a given airplane, you have to suck in the same amount of air regardless of the displacement. A bigger engine can suck that amount of air through a smaller hole.
