  • July 12, 2025, 10:06:59 AM
Author Topic: O. S. .32-F thrust washer.  (Read 1572 times)
Online Perry Rose
« on: November 06, 2017, 05:24:33 AM »
I was given a helicopter with a usable .32F. Where can I get a thrust washer for it?
Offline Bootlegger
Re: O. S. .32-F thrust washer.
« Reply #1 on: November 06, 2017, 07:16:17 AM »
 Perry, maybe tower hobbies has them, maybe???
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Dane Martin
  • heli pilot BHOR
« Reply #2 on: November 06, 2017, 08:21:59 AM »
That or call Randy Smith. He's helped me out quite a bit recently with older OS parts.
« Reply #3 on: November 06, 2017, 04:06:44 PM »
  I just got a thrust washer from an OS.28, I think it was. Current production product and it fits. Thrust washer from  .25F will fit also.. i'll have to see if I saved the header card from the package.
  Edit to Add: I found the header card. OS Part#22808000 Drive Washer for 21RF, SE,25FX,32SX This is the washer that the prop butts up against. The thin washer behind it is called the thrust washer. It should be available for the above engines also. I ordered these through the local hobby shop from Great Planes/Tower Hobbies.
« Last Edit: November 06, 2017, 07:57:18 PM by Dan McEntee »
Online Perry Rose
« Reply #4 on: November 07, 2017, 05:47:15 AM »
Thanks guys. I found the thing I was looking for, the prop washer. I didn't realize it had a thin washer in back of it. Tower has the prop washer. Minus one.
Offline Steve_Pollock
« Reply #5 on: November 07, 2017, 04:10:49 PM »
Tower lists them in stock for $4.49.  An amazon seller has them for less than that. P/N is 22620003.  Oops -- to slow!
