  • July 12, 2025, 05:44:48 AM
Author Topic: O S 30 Stunt engine  (Read 1562 times)
Offline Bootlegger
O S 30 Stunt engine
« on: September 23, 2018, 11:29:23 AM »
  What size venture, and what is a good needle valve assembly to use in this engine also?  Thanks
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: O S 30 Stunt engine
« Reply #1 on: September 23, 2018, 06:35:13 PM »
Back mid 70's , The OS 20 from Radar Co in Kowloon , H K , came I think with three venturies .
Fitted the largest of these which was smaller than the stock .30 one . Drilled for spray bar .
OS 30s quite tourquey , so 10 x 6 T F was fine .
« Reply #2 on: September 24, 2018, 01:45:13 AM »
'Legger,
I have a pair of pretty worn S-30s. Used them in an Umland Super Combat Streak, set up as a sport/stunt plane. It is pretty light, what with the Umland wood selection and a MonoKoted wing. The engine with the better piston-liner fit runs super steady with a classic stunt run, but not great power any more. It has a nylon .257 ID venturi with an OS needle (.135 OD) thru the hole in the case. That results in a flow area of about 0.0172 in^2. It is very happy on 10% nitro and 28% castor. I used a Jim Lee tongue muffler with 10 3/32" holes. No issues with the OS needle valve. Even the more worn engine starts cold easily and runs beautifully, but has less power. Hot starts need more technique. I've been tempted to purchase a new P/L and put it back to work....
I forget what prop I had on this combination as I pulled it out for an OS S-35 recently. But it was definitely a wood prop and probably a 9x5 or 9x6, and possibly a 10x5. I just don't remember. The plane was too slow for good line tension on 60' (it is a Flight Streak, after all) but the engine setting that made it happy just didn't pull enough prop. A thinned-down prop or a carbon prop would help unload the engine and make more of the power useful. I don't like flipping carbon props on sport planes. It was just easier to swap the engine for now.
Wish you the best with yours,
Divot McSlow
Offline GERALD WIMMER
    • Auckland Free Flight Club
« Reply #3 on: September 24, 2018, 03:59:17 AM »
Hello My wife has a stock OS 30S on a Skyray she has flown for over 20 years (flew it on Sunday just past). The motor prefers to rev on a smaller prop (8.5x6) with a big venturi .275 and stock fat OS spray bar (4mm) and peace pipe with muffler pressure. Very steady and reliable combo. Regards Gerald
Offline Bootlegger
« Reply #4 on: September 24, 2018, 08:56:31 AM »
 Thanks a lot fellow's that helped a lot, now where can I get the venture "O" ring for the O S 30 venture?  In all of this the "O" ring disappeared !!!
Gil Causey
AMA# 6964
Offline Bootlegger
« Reply #5 on: September 24, 2018, 03:17:22 PM »
  I found some "O" rings in a "stash" of O S parts, now the next project is drilling the case for a tongue  muffler, suggestions??  Thanks
Gil Causey
AMA# 6964
« Reply #6 on: September 24, 2018, 06:19:01 PM »
