  • June 21, 2025, 09:08:29 AM
Author Topic: O.S..25 FP launch rpm?  (Read 1345 times)
Offline Terry Caron
« on: May 17, 2015, 07:20:31 PM »
Hi all -
What's proper launch rpm for a .25 FP, 9-4 APC, 400 sq in, 28 oz?
I've flown a FS/.20 FP at ~11.8K launch, but on the bench the .25 is in solid 4-cycle at that rpm.
4-2's pretty sweetly tho'.  ;D
Thanks.
Terry
NACA member, Huntsville, AL
AMA 249824
NRA Life Member
Re: O.S..25 FP launch rpm?
« Reply #1 on: May 17, 2015, 08:57:43 PM »
   I would say that you would be in the ball park at the same RPMs as the FP-20, or at least a good starting point. I ran a FP.25 on my P-Force and would take off at 10,500 RPM with an APC 10-4.
   Good luck and have fun,
Offline Terry Caron
« Reply #2 on: May 17, 2015, 09:45:55 PM »
So you were running a 4-2 cycle Dan?
Also, I was wondering if the .25 "should" have a larger prop than the .20; 9-4 is commonly said to be best/largest for it.
Terry
AMA 249824
NRA Life Member
« Reply #3 on: May 17, 2015, 10:25:45 PM »
  "Best" and "largest" are definitely NOT the same thing. Back in the old days, the only way to harness more power was to use a bigger prop. That's not at all true for these engines. The 25FP would probably swing a 11.5-4 fast enough to fly a Twister-sized airplanes, and I have seen people use 10-4 Tornado 3-blades on 20FPs with adequate performance (on a Ringmaster, of all things). For a Twister, for example, I would suggest something like a 10-4 Rev-Up (inefficient so it wastes some of the excess power).
    A 25FP with a 9-4 probably wants to run about 14,000 on the ground to wind up in the right setting in the air. Then see what you get. If you get too much speed (likely, depending on which model we are talking about), then you might want to look into using an air filter or start restricting the venturi. That's why I think the 25FP is too big for these smaller 35-sized models, you have to choke them down excessively.
Offline Terry Caron
« Reply #4 on: May 17, 2015, 11:01:28 PM »
OK Brett, guess I'll rethink the .25.
I have .20 FPs also, maybe a better match.
Thanks.
Terry
AMA 249824
NRA Life Member
