  • July 16, 2025, 09:51:50 PM
Author Topic: NVA Sloppy fit - What to do  (Read 1252 times)
« on: May 15, 2012, 08:34:31 PM »
I have a LA .46 that I had a ST NVA in that did not work out right. I would like to put a OS NVA back in this engine.
So I'm sure someone has done this before.
Was thinking I could put JB Weld around the holes in the case to fill the gap?
Or cut some gaskets?
What do ya think?
Offline Russell Shaffer
Re: NVA Sloppy fit - What to do
« Reply #1 on: May 15, 2012, 08:39:26 PM »
I have used nylon washers, basically the same as gaskets.  I don't think you could keep the JB Weld in the holes, and if it got into the engine it might be bad.
Russell Shaffer
Klamath Falls, Oregon
Online Martin Quartim
    • StuntHobby
« Reply #2 on: May 15, 2012, 08:59:44 PM »
Get a PA NVA or Enya NVA Pro.  The spray bar diameter is probably a bit bigger then the ST one,  and they work much better then the ST NVA.
Enya also has special set of washers (P.N.  SP4WS or something like that)  that you can use to center the spray hole right in the center of the venturi for any engine.
Martin
    • StuntHobby
« Reply #3 on: May 15, 2012, 09:05:43 PM »
The P.N for the Washers is SPW4S
Enya NVA Pro ( It has a Nylon bushing that makes it air tight)
Randy Smith should have these parts.
Martin
« Reply #4 on: May 16, 2012, 10:34:15 AM »
Thanks guys.
I think the NVA is ok. It's my cowl. It is not a split cowl and I can not tighten the collier nut. Hence I need a screw in needle like a OS.  HB~>
Washers may work.
Offline Geoff Goodworth
« Reply #5 on: May 16, 2012, 07:22:00 PM »
Steve Rothwell has these in Oz. Maybe Randy or Henry Nelson does something similar. Knob diameter is 20mm, length is 35mm, hex is to suit the Randy Smith style spraybar collet.
« Reply #6 on: May 17, 2012, 10:59:02 AM »
That would do it !!!
Randy?
