  • August 01, 2025, 10:01:28 AM
Author Topic: Fox .36 Slant Plug Fuel?  (Read 1637 times)
Offline David Ruff
« on: March 22, 2018, 04:02:20 PM »
I have a new and never run Fox .36 slant plug engine.
Do I need to run the 29% castor in this or can I go with something more modern?
Photos are here for ID of engine.
Planning to mount on my Corehouse Gotcha Streak III.
Retired Army
Re: Fox .36 Slant Plug Fuel?
« Reply #1 on: March 24, 2018, 05:08:22 PM »
Dave,
Since this is an Iron P/C do the break-in with 5% nitro and at least 25% - 28% total oil. I would use a 9x6 prop. Due short rich runs for the first 20 - 30 minutes, pinching the fuel line occasionally to bring it to a burst of 2 cycle. After that you can either fly it rich for another 30 minutes or run it on the bench till it hold a rich 2 cycle without sagging. Once you get to this point you can bump the nitro to 10% and use 25% total oil (50/50).
Best,    DennisT
« Reply #2 on: March 24, 2018, 05:24:58 PM »
David
NO  do not use  28% castor  you will ruin the motor faster, as you will with about any motor, use  1/2 to 1/4 synthetic  and  make  sure  you have at least  25%  oil total,  Break in very rich, almost sloppy rich  to start  then  put the motor into a  4 stroke  that has lots of smoke  blowing,  do this for 1 to 2 runs, after that  if the motor  feels good, not tight, then run in a 4 cycle  with pinching the tube, or  turning the needle  so it  bleeps into a  2 cycle, you want to, at this point, start to heat the motor up more, so it  breaks in near the running speed.
I use a  10 x 3 prop  for break in, or  a  11 x 3  will work well
Most of these  needed  10 to 15 tanks  to do your  breakin .
I have a n  article  pinned at the  top of the forum  you should  read, care and Feeding of the stunt engine
Nitro percent will not matter for breakin , but  no need  to waste money  using  high nitro fuel,  I use  5%
Also  I had boxes of these, as I used  them  for  Stunt   SPORT  and  Slow Combat, both  in  29 and  36  size
« Reply #3 on: March 24, 2018, 05:29:11 PM »
 So what percentage do you try? For motors like Fox .35s, OS Max 35s or the old McCoy’s and K&B’s, use a fuel with 26 to 28% oil content; preferably half castor and half synthetic, up to 75% castor  is OK. These  motors have very small bearing surfaces, and are subject to much wear and heat, most are all plain bushing motors and most have unbushed rods. They need a lot of  oil  to help cool the engines. Since these motors run hot, they need  extra oil to keep them lubed,clean, and to carry out heat . If you have one of these that is  in very good  shape but, is  just starting to get some brown or black varnish plating on it, the synthetic mix will clean it  up for you, resulting in increased life.  Do not use the synthetic  blend in an old motor that has a lot of time on it with all castor fuels; the synthetic will remove the castor varnish off the piston and sleeve and will in some cases, leave you with the worn-out motor that had to start with.  Also always try to NOT use  prop shaft extensions with these engine, as it adds a  lot of  wear on the crankshaft bearing.
Offline David Ruff
« Reply #4 on: March 25, 2018, 05:41:09 AM »
Thanks, guys.  I have basically been breaking in like Randy says.  It runs good.  I did dump some 20/25 in for a short run.  Had to open the needle almost to the point of removing it to keep a 4 stroke run.  LOL.
But it is OK.
Went back to 10/23 and it likes it.
I will continue to break in on bench.  Then mount on the Gotcha Streak III.
It is a monster engine; lots of power there.
I am using a 10-5 prop to break in.
I can see how it would swing a larger prop.
Interesting engine.
Retired Army
Offline David Ruff
« Reply #5 on: March 26, 2018, 04:12:13 AM »
I read somewhere this has a spraybar with two holes?  I have to check it out.
It was loose when I first started it.  I tightened up the fitting and oriented the hole like most, down.
Retired Army
Offline David Ruff
« Reply #6 on: March 26, 2018, 11:06:27 AM »
Amazing what happens when you remove the spray bar and find it is clogged, then clean it.
This thing runs strong and starts easy.
I am beginning to think it is too much engine for a 30 oz Gotcha Streak III stunter.
Retired Army
