Gentlemen,
My flying buddy, Ralph, purchased a new NV Big MiG 0.25 engine.
We proceeded to break in the engine. Took the following actions;
1. Cut down a 10X6 prop to 9X6 and balanced the prop.
2. Used 10% nitro, 10% synthetic, and 10% castor fuel.
3. Ran 8-10 times with a 6 ounce tank of fuel for 50-60 minutes run time.
4. Ran the engine very rich. Never had a lean run.
5. The engine ran 9800 RPM on the plastic 9X6 prop.
6. Also, ran at 10800 RPM with a wood 8X6 prop.
7. The centerline of the fuel tank was at the center of the needle valve.
8. We relocated the tank to 1/2 above the needle valve.
8. It takes 4 turns out of the needle valve to get the engine to run.
The more we broke in the engine, the less compression the engine had.
The more we broke in the engine, the harder it was to start.
Now, it will only run for 2-3 minutes and then quit.
The engine will not run when leaned out.
The engine appears well built. The craftsmanship of the engine is very good.
The NV distributer stated he had never had a complaint. He did not have any suggestions on changes.
Any suggestions;
other than making a fishing weight with the engine.
Thanks for any informative suggestions.
T Michael Jennings
Knoxville, TN
