  • July 08, 2025, 03:30:16 PM
Author Topic: Norvel engines  (Read 2801 times)
Offline fred krueger
Norvel engines
« on: August 04, 2010, 03:39:18 AM »
This was posted this morning on the Barton forum.  Anyone have knowledge of this??
Fred
Subject: Re: norvel engines
To: xxxxxxx@yahoo.com
Date: Monday, August 2, 2010, 10:59 PM
Hi James,
The Norvel production is back, but it is called NV now. Below is the price list. Thank you
Alex Frish
NV rep in the USA
Item Part number Price
Norvel Big Mig 0.049 CL $60.95
Norvel Big Mig 0.049 RC $63.95
Norvel Big Mig 0.061CL $69.95
Norvel Big Mig 0.061 RC $72.95
Norvel Big Mig 0.074 RC $84.95
Norvel Big Mig 0.15 RC $89.00
Norvel Big Mig 0.25 RC $95.00
Norvel AX-40 RC BB Revlite $109.00
Crankcase 06 100108-01 $22.99
Crankcase 07 100108-02 $23.99
Crankshaft 06 100110-01 $18.95
Crankshaft 07 100256-01 $19.95
Cylider/Piston assembly Big Mig 04 100406 $24.95
Cylider/Piston assembly Big Mig 06 100402 $27.95
Cylider/Piston assembly AME 06 (limited stock) 100401 $37.95
Cylider/Piston assembly Big Mig 07 100407 $29.95
Cylider/Piston assembly AME 15 301004-03 $35.95
Wristpin 04-06 100103-03 $3.95
Wristpin 07 110103-01 $3.95
Connecting rod 06 100113 $7.95
Connecting rod 07 100113 $8.95
Head wrench 04-07 230131 $3.95
Head wrench 15-40 230132 $9.95
Glow plug 04-06 110138 $7.95
Glow plug 07 110158 $8.45
Head adaptor for std. glo plug 04-06 100148 $4.29
Head adaptor for std. glo plug 07 120131 $4.39
Cover plate 04-06 100100 $7.95
Cover plate with a pressure fitting 06 100100(f) $12.95
Cover plate O-ring 04-06 300209 $3.29
Cover plate O-ring 07 100209-06 $3.29
Spring starter 102105 $6.95
Cylinder head gasket 04 (2) 100112-01 $3.29
Cylinder head gasket 06 (2) 100112-01 $3.29
Cylinder head gasket 07 (2) 100116-01 $3.49
Glow head gasket 04-06 (3) 100117 $2.99
Glow head gasket 07 (3) 101717 $2.99
Needle valve screw 04-25 120114 $8.95
Prop screw 04-06 100137 $1.95
Prop screw 07 100337 $2.50
Prop spinner 04-06 100102 $4.95
Prop spinner 07 100302 $4.95
Prop spinner & screw set 100153 $6.49
Prop hub 04-06 100124 $5.95
Prop hub 07 100124-01 $5.95
Drive gasket 04-06 100136 $1.99
Drive gasket 07 100136-2 $1.99
Venturi assembly 04-07 (without needle) 101159-02 $14.95
Carburator assembly 04-07 (without needle) 110159RC $22.95
Venturi O-ring 04-07 100209-05 $2.89
Throttle lever 04-15 100202 $3.95
Throttle lever stop spring 04-07 100204 $2.89
Throttle lever stop screw 04-07 100205 $2.89
Venturi nut 07 100281 $2.89
Venturi screw 100291 $2.89
Cylinder head screw 04-06 (qty 4) 100127 $4.39
Cylinder head screw 07 (qty 4) 100325 $4.49
Muffler 06 101003-05 $9.95
Muffler pressure spring 04-06 110120 $2.99
Muffler assembly 07 110157 $22.95
Head 04 110131 $5.95
Head 06 110131 $5.95
Head 07 120131 $5.95
Diesel head (conversion to diesel) 04-06 400401 $22.95
Wire net 04-07 100122 $3.49
Fuel tank mount 06 102100 $13.95
Prop spinner 25 400400 $5.95
_________________
Offline kenneth cook
Re: Norvel engines
« Reply #1 on: August 04, 2010, 02:10:00 PM »
       I truly hope this isn't rumor. I think this is great news as I own several and all of them have been my favorites. I damaged a few over the past few years breaking needle valves and also cases. I truly would love to fix some of these and continue on. Hopes run high but Ebay  really hasn't been much help in my quest for parts as it seemed as Sheldons hobbies supply of big mig  parts for the .061-.049's pretty much dried up. I have engines with the NV logo  currently casted into them. I thought this stood for Northern Velocity. I had one of my.15's get damaged in a combat match which resulted in a horrific shaft run which was brutal on the performance of this engine. The crank has a threaded stud which holds the prop on which when subjected to the ground resulted in breaking of the stud and losing the drive washer, prop washer and also the prop nut. I cherish my collection of them and will truly buy more as I feel they're a terrific running 1/2 a small engine. Ken
Offline dennis lipsett
Re: Norvel engines
« Reply #2 on: August 04, 2010, 04:12:23 PM »
I posted this on another forum and the response was that this was old news and one of the posters said that he had parts coming accross the pond.
Dennis
Re: Norvel engines
« Reply #3 on: August 04, 2010, 04:57:17 PM »
        Dennis, did this person leave any contact info. Maybe if I get lucky he might have some of the items I've been in search of. Ken
Re: Norvel engines
« Reply #4 on: August 04, 2010, 05:56:47 PM »
Ken,
There is an email address at the top of my posting.
Fred
