  • June 26, 2025, 02:15:24 PM
Author Topic: Thunder Tiger GP .25 R/C  (Read 2154 times)
Offline John Fitzgerald
  • No longer an AMA Member
« on: December 07, 2011, 08:35:06 AM »
I have a TT GP .25 ABC that has a few bench runs, and ready to start flying.  Thinking of using it in a Sterling F51 Brodak kit I have coming.  Is there a control line Venturi and NVA available for it or would I get similar results by wiring the throttle wide open on the R/C carb?  Maybe if it is too fast the throttle could be closed a little even?
Re: Thunder Tiger GP .25 R/C
« Reply #1 on: December 07, 2011, 11:55:25 AM »
Hi John,
You can usually wire open the carb and do fine.  I would prefer a venturi and NVA, though.  Randy Smith, Leonard Neumann, Scott Riese, etc., can come up with those pieces.
Big Bear
Offline Geoff Goodworth
« Reply #2 on: December 07, 2011, 04:11:45 PM »
John, the pinch bolt that holds the carb is 4mm dia so the ST-style NVAs from your favourite supplier work a treat and you can get venturis from those that Bill mentioned. Scott made some good ones for me.
Offline Paul Wood
« Reply #3 on: December 07, 2011, 04:32:22 PM »
John,
If you decide to use the R/C carb, here's what I do.  I set the mixture with the carb fully open.  Then I reduce the RPM by closing the carb to get the RPM I'm looking for and lock it at that setting.  To get the desired lap speeds, I set about 10,000 (I'm flying an OS 45 FSR and a TT 42 GP).  I've had no problem using this method and by reducing the carb, I get excellent gas milage.  I also fly NVA's, but I just never got around to modifying the R/C engines and use them for sport flying only.  The R/C engines are timed so high that I cannot run them with the carb fully open.
« Reply #4 on: December 13, 2011, 07:24:25 PM »
John,
Paul,
What method do you use to lock the throttle in your selected position, and to change the throttle setting after the engine is running?  Thanks.
Offline Paul Wood
« Reply #5 on: December 14, 2011, 11:02:36 AM »
John,
Here's a picture of the way I lock the carb.  But, some carbs allow you to tighen the barrel travel limit set screw.  That would be my first option, but on this carb I couldn't get that to work.  Regarding the adjustments after I set the carb, I don't change the setting.  I just use different pitch props.  However, you could make minor adjustments by altering the threaded fitting on the carb arm.  Be very careful of the prop when you are establishing the initial setting.  Also, I use an electric starter and often have to put my thumb over the carb throat creating a partial choke to get the engine to start when cold.  Hope this helps.
