  • June 21, 2025, 08:58:55 AM
Author Topic: Norvel Ame.15  (Read 937 times)
Online kenneth cook
Norvel Ame.15
« on: February 25, 2008, 04:34:06 PM »
         I purchased a .15 size AME and was wondering about the break-in procedure. I own a few of the .049's. They provided little information on the prop selection for break in on the .15. They did state 8x4 was the max. The rpm's shown for average run was using a APC 7x4. This engine was extremely tight. I first washed it in denatured alcohol as noted in the directions and re-oiled. It took about a 1/2 hour of constant flipping and re-oiling just to get it so I could flip it before attempting to start. This engine started right up but wasn't very responsive at first to the needle setting. I backed the needle out to get it to settle down. I was using a 7x4 prop with sig 15% 20% castor. The engine hardly even got warm to the touch after a 4 min run. I ran it again let it settle to a wet 2 then pinched the fuel line a few times. I believe the needle has a few leaks in it causing poor fuel draw and poor needling characteristics. The needle assembly has 4 points of potential air leaks. I believe I can remedy some of them. This particular needle screws into the venturi side and protrudes slightly into it. I'm guessing this is referred to as a sprinkler type. How fast should I be running this engine? Its been mentioned that heat cycling is the way to progressively break your engine in. This engine hardly even gets hot to the touch on the outside. I wasn't using a tach but this seemed to be howling quite loud when I was pinching the fuel line. I was wondering if I was going to do damage. I know this isn't typical to a iron piston engine.  Ken Cook
Offline ray copeland
Re: Norvel Ame.15
« Reply #1 on: February 25, 2008, 05:30:27 PM »
Hey Kenneth, i too am breaking in a Norvel AME .15. Mine was so tight that the first time i started it the piston seized up after about 10 seconds. After that i had a time breaking it loose, being afraid all the while that i was going to break the rod. But finally i got the piston freed up and after that for a while it would screech when i added fuel to it. Finally got it started again and have ran about 10 ounces of 10% nitro with a lot of castor, 8x4 prop and it runs great. Starts right up, has good fuel draw on test bench and has a lot of power. Don't have a plane ready to mount it on right now but i think it will be a great engine. Good luck with yours, let us know how it goes from here as i may want to buy another.  Ray
Online kenneth cook
Re: Norvel Ame.15
« Reply #2 on: February 26, 2008, 07:44:08 PM »
           Ray, I noted that same squeak you mentioned. I came across an old article concerning Norvel engines. It stated the need for an oil heavier than 3 in 1 to oil this cylinder first. Well, I used 3 in 1. I also heated the cylinder slightly with a heat gun as well. The article did state a good 2 cycle for run up. A rich run could do damage to this unit quickly. They recommended Marvel Mystery oil with the piston down and soaking for at least 24 hrs. Its amazing what you learn afterwards. I did purchase another one of these engines. As for my inconsistent needling, the older Norvel instructions stated this could happen due to it breaking in. I only ran it twice and it definitely sounded better on the last try. I came across a few of your posts and it appears we share the same interests.        Ken Cook
