  • June 22, 2025, 11:11:03 PM
Author Topic: Big Jim Hemi 60 .  (Read 2631 times)
Online M Spencer
Big Jim Hemi 60 .
« on: May 04, 2018, 11:20:14 PM »
Anyone let the cat out of the bag ,
pictures or drg of head / chamber .
Any Timing Mods .
Ive Found .312 for the venturie , and ' free flow ' 1/2 in outlet for muffler , for 6 Oz fuel burn - to cool , & provide decent 4-2 switch .
Other than that , We have to assumes it Hand finishing/ fettling .  S?P
Pictures Pictures Pictures , please .  H^^
Re: Big Jim Hemi 60 .
« Reply #1 on: May 08, 2018, 08:25:28 PM »
So no one has any pictures of the Big Jim's Hemi heads? It would be a shame if we lose this technology.
Best,  DennisT
Online M Spencer
« Reply #2 on: May 09, 2018, 07:13:41 PM »
Hurumph .
Contrary to popular belief ?? ??? The Double Star , and to a degree , Stalker - are said to pirate their ' specs ' ,
Particularly the DS 60 . Ive a pic of a DS 40 chamber somewhere - essentially ' a bowl ' .
The DS 60 Lite might be said to be a derivitive of the earlier ST 45/51/56 Plain Bearing 'V ' engine .
V Early 'V' 60 I have , dual ring - short rod - has open chamber ( No Squish Band -or minimal ) head .
Im presumeing maybe the Hemi is rather similar .Will recheck the timing on this ,
The Merco 49 ran steady and strong on the ( Original ) ' Stalker ' 130/110 sleeve timing .But little round shaft port .
Might try setting a pdp 60 at the 130/110 timing - for steady four stroke run , :-\ perhaps .
Im sure the ' Big Jim ' motors are out there , he mustve done a ton . Wonder if theres any destinguishing marking / engraving
or somesuch .
 R%%%% R%%%% H^^
Offline Manuel Cortes
« Reply #3 on: May 10, 2018, 10:25:13 AM »
Hi all!!
Just for the record, all Mercos (29,30,35,40,49 and 61) are Hemi head.
Kind regards from Spain.
Manuel.
« Reply #4 on: May 10, 2018, 02:48:10 PM »
Best,  DennisT
The  de-compressed  BJ Hemi heads  run very much just like  the  first  ST 60 Low Comp heads  I call the  Bell head, it is hemi  and looks like  the under side  of a Bell, no squish band,  That said  the very latest  hemi Squish  high compression head  with the  scalloped top   was/is  the  BEST head  for the  ST 60, if you have the  rest of the engine setup correctly, ie  venturi size, head shims, exhaust outlet size  etc.  You need a  larger venturi with the  hemi low comp  head, smaller venturi with the  stock high comp squish/hemi  head
I built over 600 of these for people, and a few that were  65s  and a couple of 71s and  74s
« Reply #5 on: May 10, 2018, 03:44:03 PM »
Hurumph .
or somesuch .
 R%%%% R%%%% H^^
Many of the  motors  Jm  did  had  either   BJ  or  LJ  carved nto them, and  some  had  a number  like  150 160  130   wrote on the head  . He measured  the psi on what they  read
« Reply #6 on: May 11, 2018, 08:03:27 PM »
Here are pics of a Genuine Big Jim Hemi Red Head.
Online M Spencer
« Reply #7 on: May 18, 2018, 09:51:22 PM »
Thanks.  H^^
Not B J but T L .
The cuts reduce the buckling of the piston and, from the part, help to wash the bottom of the piston behind the deflector. Useful for non-rectilinear deflectors.
The depth of the cutting is 1.6 mm. 1.7 mm, the angle at the top is 60 degrees.
From the exhaust side a chamfer is removed from the top of the cut to the bottom of the piston. See the photo from the blowdown side for a sharp edge.
« Reply #8 on: May 19, 2018, 05:52:31 AM »
Matt,
Very interesting shots of the piston baffle can you post some shots of the head? It would be interesting to know what Tom was trying to get from the baffle slits. Interesting to try to record this technology for the ST 60.
Best,    DennisT
Online M Spencer
« Reply #9 on: May 19, 2018, 08:16:36 PM »
In a WORD ; NO .  :-\
abducted Info from Russian Site . IF I find said picture there , sure will .
Last knight , dithering with Spitfire & injuns , Found the Earlier Prop Diver 60 has longer nose by maybe a quarter inch , Due To the Earlier Deeper Prop Driver .
So the a amenity to alter fit / spinner posn through that .
Ive got the Timing for the First Hemi 60 written down , will measure PDP & post them & Engine  Test of another year also .
Can Do Pictures of Above Heads , Early is Big chamber . Also in time one Herb is opening up to Hemi - narrow squish band . But That is a individual one .
Curtosey SKIP . B J on left .
« Last Edit: May 29, 2018, 06:22:50 PM by Matt Spencer »
Offline Evgeny Khromov
    • CLSTUNT.RU
« Reply #10 on: May 30, 2018, 12:24:30 AM »
This guy owns this engine. He did and pictures.
https://stunthanger.com/smf/profile/?u=34752
