Engine basics => Engine set up tips => Topic started by: frank mccune on September 22, 2015, 07:05:33 AM
Title: Noisy rear baring????
Post by: frank mccune on September 22, 2015, 07:05:33 AM
     Hello All:
     I was given a Fox .50? that was gummed badly with some type of dried oil.  I disassembled the engine and cleaned the parts as best that I could.  All went well until I installed the rear bearing.  This bearing makes a noise and has a bit of drag when it is spun in the engine.  Outside of the engine, the bearing sounds good but not perfect.
    Perhaps I did not remove all of the "varnish" from the bearing.  I boiled the bearing in dishwasher detergent, used an ultrasonic cleaner with the same strong detergent and soaked it in carb cleaner.  Can I use a solvent other than water in an ultrasonic cleaner? If so, what works well?  I have no idea as to how to clean the bearing other than soaking it in some type of aggressive solvent for a long period of time.  Perhaps I can find a replacement bearing.  What are your thoughts about running the bearing as it is?
    Suggestions?
        Tia,
        Frank McCune
Title: Re: Noisy rear baring????
Post by: Carl Cisneros on September 22, 2015, 08:08:24 AM
If I were you I would change out the bearing/bearings if you are planning on usung the motor.
An ounce of prevention is worth a pound of cure they say.
here is the link to Boca Bearing for the motor (Fox 50)
Carl
http://www.bocabearings.com/search.aspx?SearchType=StartModel&ProductGroupID=2&MFGSYSID=30&ModelName=50&Feature=50
Post by: Motorman on September 22, 2015, 11:16:06 AM
Castor has some acidity and if it's been in the bearing a long time you're probably hearing the balls running over the pitting from corrosion. If it's just dried castor then Castrol Super Clean is a strong alkaline that will melt dried castor no problem.
After run while the engine's still hot, disconnect the fuel line then take 75% naptha 25% ATF squirt some in the venturi and run the prime off, do this 3 times. It will flush out the nitro and castor and leave everything coated with ATF. On my iron pistons I put one more drop of atf on the piston and work it in. Don't let castor dry out in your bearings.
MM
Post by: RandySmith on September 22, 2015, 12:08:46 PM
     Hello All:
    Suggestions?
        Tia,
        Frank McCune
Hi Frank
just buy a new bearing, that bearing is not worth using, also stay away from powerful dish washing agents, I have seen many of them rust/corrode steel bearings, and many will tell you to never put a bearing in an ultrasonic cleaner, it damages the balls and race.
If you want to clean them, use Berry's carb cleaner in the dip can, or Green Antifreeze in a crock pot, then immediatly wash and oil the parts
Post by: frank mccune on September 22, 2015, 01:48:24 PM
    Hi All:
    Thanks for the replies.  I think Randy has the correct idea.  Now to find a bearing supply house in my area.
    What am I going to do with this engine when I get it running? Lol
        Be well my friends,
        Frank McCune
Post by: Fredvon4 on September 22, 2015, 04:58:52 PM
  Unless you go exotic with ceramic, the BOCA bearings, (even the cheap set) are priced OK, pretty good, fit, and ship fairly fast
