  • June 22, 2025, 05:05:40 PM
Author Topic: ST. 40 and 45  (Read 877 times)
Offline Jim Pollock
ST. 40 and 45
« on: January 14, 2007, 09:02:02 PM »
Randy,
Have you had any experience with the new ST .40's and .45's?
If so, what's your take on them.....
Jim Pollock   ???
Re: ST. 40 and 45
« Reply #1 on: January 14, 2007, 10:20:56 PM »
Randy,
Jim Pollock   ???
Hi Jim
I would not use one for CL stunt, the would be far behind the ST 51 which can be a very good engine. If someone just wanted to use one, you could try setting one up for low pitch wet 2 runs, or decompress for a  higher RPM 4-2
Are you wanting to use one of the motor?
Offline Wayne J. Buran
Re: ST. 40 and 45
« Reply #2 on: January 15, 2007, 04:07:07 AM »
We have them in stcock, including the Fox Hemi button and the L&J Fox head.
Wayne Buran
Buran's Antiques and Hobby's
Wayne Buran
Medina, Ohio
AMA 14986 CD
USAF Veteran 35 TAC GP/ 6236 CSG, DonMuang RTAFB, Bangkok, Thailand 65-66 North Coast Controliners   "A fine is a tax for doing wrong. A tax is a fine for doing well!
Offline Jim Pollock
Re: ST. 40 and 45
« Reply #3 on: January 16, 2007, 03:30:05 PM »
Randy,
I'm not wanting to use one - I was curious about them because they looked like mini ST .51's
I'll stick with GOOD engines!
Jim Pollock   mw~
