  • July 07, 2025, 10:48:59 PM
Author Topic: What Size Venturi for Merco 61  (Read 1127 times)
Offline Brian Thwaites
  • ACE
« on: June 18, 2008, 01:40:38 PM »
My Merco 61 has Venturi size of .260" I think it is too small will not get much above 8800 RPM 13 x 6 prop
think it needs more ummph suggestion on correct size would be much appreciated. Its a new engine with about an hours running in
Brian Thwaites
Offline Bill Hummel
Re: What Size Venturi for Merco 61
« Reply #1 on: June 18, 2008, 02:34:12 PM »
Brian, depending on which version of the Merco, we've seen venturis of .285 up to .305 generally.  You might not get much more that 8800 rpm's; the Merco likes that neighborhood.  Also, until more time is on the engine, try a 12/5 or 12/6 prop, and at least 50/50 fuel.  Nice engines for stunt, old-fashioned "luggers".
ama 72090
Dave Adamisin
« Reply #2 on: June 18, 2008, 03:00:36 PM »
Hi Brian. What Bill said. Also the needle body dia has an impact on this question. The stock Merco (memory kicking in) was I think ~0.155" dia which makes the .260 pretty small. I would start with opening it to .281 and then as high as .304. Probably need muffler pressure for .304. If it's the smaller .135 body .281 is a target for the high end.
  • ACE
« Reply #3 on: June 18, 2008, 08:25:04 PM »
thanks guys will measure needle valve and work up from there
Brian Thwaites
