  • July 17, 2025, 03:44:34 AM
Author Topic: Does Anyone have a diagram of the Brad Walker Clunk tank set up?  (Read 1269 times)
Offline Walter Hicks
Having some not fun issues with my clunk tank and would like to see a diagram of the Brad Walker set up.Thanks
« Last Edit: May 22, 2018, 07:30:42 PM by Walter Hicks »
Re: Brad Walker Clunk Tank Set Up
« Reply #1 on: May 22, 2018, 07:21:44 PM »
I have a Sullivan 6 ounce flex tank with tubes forward and normally use two tubes to clunk one for pick up and one attached to tube soldered to clunk for uniflo. I also may try John Miller set up.
« Last Edit: May 22, 2018, 08:00:22 PM by Walter Hicks »
I run the same tank with the uniflow (muffler pressure) vent in the inside forward top corner and the overflow in that little bubble.  Runs great.  I have also run the muffler pressure in the little bubble.  That works if I put 4 or less oz in the tank.  I have also had success with your set up.
Re: Does Anyone have a diagram of the Brad Walker Clunk tank set up?
« Reply #3 on: May 23, 2018, 02:18:59 PM »
Well for whatever reason the 3rd Sullivan clunk tank with the Uniflow line attached to the clunk worked very well. Dont know why it was any different than the others I tried the only really strange thing is it goes crazy lean when I do the 3 inside looks and is fine after that both upright and inverted.
So this contest will be a lot more fun than I thought  :) :)
