Randy,
I've hit some problems with my PA 61/pipe set up on my Tempest (same set up I spoke with you about). I went out this afternoon and couldn't get a needle setting. First flight was a bit fast, opened the needle on the second and was slow and so on. A couple of time when I tried to set the needle I opened it 1-1.5 turns with no change then it would start to sound like a sick Harley. I tried several props, all 12 3-blade, pitched at 4, 4.2, 2.3. I'm wondering if I may have toasted the pipe (there was a horrible smell coming from even after I got home, not sure how to describe it).
James
