  • June 21, 2025, 12:17:49 PM
Author Topic: New Enya SS40 BB  (Read 2689 times)
Offline David Ruff
New Enya SS40 BB
« on: June 15, 2015, 04:25:08 PM »
Holy cow.  Breaking in this Enya on the bench.  I have run about 4 tanks of 2 oz so far.  Just fired it up with one flip.  It runs like a raped ape.
Not seeing any 4 cycling at all so far.  I start with recommended 3 turns open.  Runs great, but FAST.  LOL.
I am running 10% nitro and 24% oil.
Did I mention it starts on one flip.  I am getting a consistent run at this point.  No sagging at all.  Just FAST.  Did I mention 2 cycle FAST.
It may be a fast stunter.
I am planning to use for a Cardinal.
This thing could probably haul a .60 size plane.
By the way, it starts best by smacking the prop backwards.
Retired Army
Offline dennis lipsett
Re: New Enya SS40 BB
« Reply #1 on: June 15, 2015, 04:32:22 PM »
You can open the needle valve if you want to slow it down and run it richer. They are good engines but take a bit of running to be consistent
I have a few and they are all keepers. Remember that slowing the engine down is not a method of slowing the model down but it is useful for running in a new engine to insure lubrication and temperature control.
dennis.
Offline Bill Johnson
« Reply #2 on: June 16, 2015, 05:09:57 AM »
I have 2 I bought, used R/C versions, cheap. I think the R/C guys never broke them in. Swapped the carb for a 7mm venture and an Enya NVA. After a couple short runs, I ran a full 10 oz tank of GMA 10/29 then another tank of GMA 10/22. I flew one on a Brodak P-40 on an APC 11.4 X 4 and 62' lines. Lots of line tension and lap times weren't too bad. If I hadn't destroyed it in crash #4 this year, I'd probably switch to an 11 X 4 prop and 63' lines. Great engines.
Best Regards,
AMA 350715
Offline Chris Wilson
« Reply #3 on: June 16, 2015, 06:37:12 PM »
MAAA AUS 73427
Offline Martin Quartim
    • StuntHobby
« Reply #4 on: June 19, 2015, 12:15:15 PM »
If you use a low pitch prop and high rpm, be aware and prepared to deal with fuel foaming. If fuel foaming happens you won´t be able to adjust rpm with the needle. If you need help how to deal with fuel foaming do ask so we can help.
You may want to check with Randy Smith for a lighter CNC tube muffler for your engine.
I flew with this engine, but w/o BB, in a Pathfinder with an APC 12x4  and I agree with you, it is powerful enough to fly anything up to 60oz.
Martin
Offline Brian Hampton
« Reply #5 on: June 19, 2015, 10:50:56 PM »
The SS 40BB came with either an optional iron piston or ringed alloy piston which could determine how much oil to use.
