  • July 14, 2025, 01:09:46 AM
Author Topic: New? Enya 35 Classic  (Read 22635 times)
Offline Lauri Malila
Re: New? Enya 35 Classic
« Reply #50 on: April 30, 2016, 06:01:58 AM »
I say homeopathy. :)
But, these are stunt engines and not high performance engines. More often I have found myself fighting against overcooling, not overheating. So propably it is just fine as it is but certainly I would be interested in trying what better cooling would do.
Besides, it is allways easier to increase temperature if need comes. And you save some grams, too!
L
« Last Edit: April 30, 2016, 06:22:46 AM by Lauri Malila »
Offline Chris Wilson
« Reply #51 on: May 01, 2016, 03:22:42 PM »
I like your sense of humour Laurie but all joking aside I reckon that the budget was spent on anodising rather than a milling operation simply as a point of difference in marketing.
MAAA AUS 73427
Online RandySmith
« Reply #52 on: May 01, 2016, 05:43:51 PM »
The milling could have been done as a standard part of making the head, BEFORE the anodizing, would require very little extra
« Reply #53 on: May 02, 2016, 07:14:50 PM »
Would look great with fins!
Doesn't look all that bad in the ARGO II, but the model is cut for the OS LA 46.
Now would be the time to make the change.
Charles
« Reply #54 on: June 04, 2016, 02:55:56 PM »
For anyone interested, the Enya Classic .35 Red Head is back on ebay. 149.95
10 available for those that may want one.
Different case though, has the square venturi case.
Wonder why more of the other .35 Classic wasn't produced, like the first offering?
Charles
Offline pat king
    • PDK LLC
« Reply #55 on: June 04, 2016, 06:13:01 PM »
The 35 Classic Type A has a 35 III crankcase with a 29 V front housing, bearings and crank. It has the white plastic venturi insert.
The 35 Classic Type B has a 35 III crankcase, front housing, bearings and crank. It has a neat looking aluminum venturi insert.
The round venturi Model 5224 B engines were never produced as ball bearing engines. When the Model 5225 engines came along they were produced in both the ball bearing and bronze bushing plain bearing configuration.
Pat
Pat King
Monee, IL
AMA 168941
Offline Bill Johnson
« Reply #56 on: January 06, 2017, 08:28:03 PM »
Just an update on this thread, Bob (shtterman on ebay) has 2 of the Type B engines for sale but what I found interesting is that the square aluminum venturiis are available as spare parts.
http://www.ebay.com/itm/ENYA-29-35-MODEL-5224-35-CLASSIC-C-L-VENTURI-SQUARE-ALUM-/291983851350
Best Regards,
AMA 350715
« Reply #57 on: January 07, 2017, 08:59:09 AM »
Bill,
That engine has been listed and relisted a few times. Seems there's little interest in it?
Charles
Offline pmackenzie
  • Pat MacKenzie
« Reply #58 on: January 07, 2017, 09:07:43 AM »
Bill,
Charles
Or it could be a good selling regular item, since he has "more than 10 available"  :)
MAAC 8177
« Reply #59 on: January 07, 2017, 09:28:26 AM »
Could be, but I don't remember seeing 10 available of this particular engine?
I see 3 available currently, so you may be correct about sales.
The engine didn't sell in December, however many he has?
I purchased the one with the round case venture. I hope it's a good engine?
Charles
Offline pmackenzie
  • Pat MacKenzie
« Reply #60 on: January 07, 2017, 09:39:35 AM »
The link you quoted was not to the engine, but rather to a venturi insert, that is what I followed and commented on  :)
I suspect all of his engines sit for a while, just the nature of selling to a smaller market.
MAAC 8177
« Reply #61 on: January 08, 2017, 08:12:17 PM »
..yes, to absorb heat, but how about transferring it into airstream? I'd just chuck it in lathe and cut some cooling fins, a little like that:
Re-reading a little bit of engineering, anodizing ups the emissivity of shiny, raw aluminum from.06 or so up to .8 or so.  Just letting the shiny finish naturally oxidize ups the emissivity(radiation emission) up to .6 or so.  So a heavy anodized coating can make a substantial increase in heat dissipation.
I think I'll anodize a head on an F2D engine and see what happens.
« Reply #62 on: January 09, 2017, 07:10:48 AM »
I'd love to try one of the new engines but they're a little pricey for me. I'm buying a couple of the new venturiis for my older engines. They originally came with 3 different size venturiis, 7, 7.5 and 8mm. 2 of mine, bought used, have the 8mm while the new venturiis are 7.5mm according to Bob.
« Last Edit: January 09, 2017, 02:14:56 PM by Bill Johnson »
Best Regards,
AMA 350715
