Engine basics => Engine set up tips => Topic started by: RandySmith on November 19, 2007, 10:56:43 AM
HI Everyone
I have new cnc tongue mufflers for the ENYA 60 and others with 42mm bolt span
Also all CNC tongue mufflers are back in stock, Plus new ones for the ST G-34
Regards
www.aeroproduct.net
42 mm, about 1.65 inch ? Goody, something to fit my os 65 la.
Any plans to do a 47 mm tongue muffler for a supertiger G90 or similar ?
The STG90 case has enough meat that I could poke another hole in the exaust flange and use a 42 mm muffler, would be a bit off-center but that probably would not matter.
