CLICK HERE--><--CLICK HERE
Never Had Any Luck With Oval Wedge Tanks.
Started by Motorman, August 27, 2026, 05:20:59 PM
Previous topic - Next topic
0 Members and 2 Guests are viewing this topic.
Colin McRae
Quote from: Motorman on October 02, 2026, 12:50:41 PMI'm dragging too much line .015 x 60. If you could see my field you'd understand why I can't risk a fly away. Besides I bought a 1000' spool of this stuff and it's just a sport plane.
I did crash it once and I glued the nose back on with some out thrust by accident so, dumb luck was working for me on that one.
The venturi is one I made at .250" when I still had my venturi making machine. I know .218" was a big jump down but I'm working with tubing sizes here. I'll have to check part numbers on the stock one for this engine.
Fly-A-Thon tomorrow.
I fly a Skyray 35 with OS 25 LA (only because I don't own a 20 FP). It is really too much engine for the Skyray. But I do run it with a 0.250" venturi where the effective area is 10% smaller than OS stock. Runs quite well IMO.
Also, if the goal is to slow down the Ringmaster, one might try an APC 9-3 prop (APC calls it a combat prop), or a MAS 9-4. I have never measured the pitch on the MAS but most report that the MAS props in general are a lower pitch than advertised. Maybe more like a 9-3.5 plus it is less efficient compared to APC sport props.
I have run both the APC 9-3 combat and the MAS 9-4 on a 25 LA on a Flite Streak, and it does slow the model down a bit. As I remember the MAS 9-4 was a little slower compared to the APC 9-3 combat.
Worth a try.
Colin
Michael LeGate
Just curious- Does the entire tank center of mass have to move, or just the location of the pickup/univent? Could a wedge tank simply be tilted up/down at the outboard end to get a consistant run?
Quote from: Michael LeGate on October 07, 2026, 03:58:50 PMJust curious- Does the entire tank center of mass have to move, or just the location of the pickup/univent? Could a wedge tank simply be tilted up/down at the outboard end to get a consistant run?
   No, you can move the pick up tube, and if using uniflow, moving that tube will affect the run. Tilting the tank to raise and lower it to change the run should work also, I would think. I've seen guys make custom tanks with the wedge off set to address the issue also. You just don't see it a lot.
   Dan  McEntee
Like Like x 1 View List
Motorman
Could someone tell me the diameter of the remote needle valve spray bar that comes on the LA 25?
MM :)
Brett Buck
Quote from: Motorman on October 11, 2026, 12:01:15 PMCould someone tell me the diameter of the remote needle valve spray bar that comes on the LA 25?
  Same as the regular spraybar - .137/3.5mm nominal.
Motorman
#55
So if my math is mathin' stock venturi is .260 with .137 nva I would have to go about .280 with the Tiger nva (.156)?
I'm shooting for 4.7 sec lap times because I want this to be my windy weather flier for Old Time Stunt. I was getting that with the .250 venturi/ ST nva but, was on the edge of over heating with no reserve power for the Vertical eight. Tried a couple different props, same story. Got 5 flights in for the Fly-A-thon. Came back in and pulled the head to make sure it only has one gasket and it did. I have a .268 ventui I want to try. I need to get my speed at a slightly richer setting.
Motorman
Got in 4 flights today. It was hotter at 85f, didn't seem to effect anything. Plane was great with the bigger venturi. Lap times were 4.75 at the beginning and 4.65 at the end with the engine running rich enough in level flight to have power in the 3 vertical eights. The venturi choke area is still slightly smaller than the factory parts but it worked good.
Balancing the speed that the airplane needs with the mixture the engine needs has been an interesting and eye opening exercise on both of these planes.
I have a wide wedge 3oz tank on the Ringmaster but only fill 1-3/4oz to do the pattern. If I change to a medium wedge 2oz tank would it get a different effect from the muffler pressure?
MM :)
Brett Buck
Quote from: Motorman on October 14, 2026, 04:07:22 PMBalancing the speed that the airplane needs with the mixture the engine needs has been an interesting and eye opening exercise on both of these planes.
 Excellent!  This is the most critical and most basic thing to come to grips with setting up stunt engines, you have to be able to get the engine in a workable range (and be able to realize it) before any of the other tweaks could make sense.
