CLICK HERE--><--CLICK HERE
Never Had Any Luck With Oval Wedge Tanks.
Started by Motorman, August 27, 2026, 05:20:59 PM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Motorman
I was rumaging through some boxes and I found a 3oz tank I made that worked good with a Veco 19. Drilled a couple of new holes in the fuselage and we're going to try it on muffler pressure. Feed line is short and low as suggested and uniflow vent is plugged. Odd thing is this tank is 1-1/2" thick so, we'll see tomorrow.
MM :)
Brett Buck
#26
Quote from: Motorman on August 30, 2026, 05:53:50 PMI was rumaging through some boxes and I found a 3oz tank I made that worked good with a Veco 19. Drilled a couple of new holes in the fuselage and we're going to try it on muffler pressure. Feed line is short and low as suggested and uniflow vent is plugged. Odd thing is this tank is 1-1/2" thick so, we'll see tomorrow.
MM :)
  That is very similar  the original Skyray hard tank:
Note that it is 1 3/4 wide, but I have about 3/16" of pads/shims/repairs under the engine lugs. To explore how wide it could be and still work (as described earlier), I started with it flat against the fuse so the pickup was offset about 1 9/16". This worked without pressure on uniflow, so good. Then I put successively thicker shims, 1/8" at a time, to see how far it could tolerate. Still worked with 1 11/16 as it was, and then 1 13/16 it was more-or less OK, but worked better with pressure. 1 15/16 would not work on pressure into the uniflow tube, but did work with pressure into the overflow (with the uniflow plugged, i.e. suction tank) and occasionally went over the top lean toward the end of the tank. With pressure into the overflow as I moved it further out, it started diverging to over-the-top-lean earlier and earlier. Pressure into overflow was always more tolerant and the mixture variation over the flight is not a big deal.
   Moving it fore and aft made no difference, as expected.
   I repeated the same test with a Sullivan SS-4 clunk tank with very similar results, and it was a little more tolerant since the line drag of the clunk tank is - for reasons I don't understand - lower. This is a HUGE, transformational change on 4-strokes but hardly detectable most of the time in 2-strokes, particular the tiny engines like this. It won't work with the wide direction horizontal, it needs the wide part vertical, so put the big flat bottom part up against the fuselage.
   This has since been tested ad hoc by *many, many* people, inadvertently, with results pretty much identical to yours, and in every case using either the clunk or the tank shown (which I just recently retrieved from someone that I loaned it to about 25 years ago) fixed it.
     So - while this may not be the only problem, having the tank wider than about 1 3/4 (preferably 1 1/2) is probably going to cause you a problem, not using muffler pressure will give it more margin, and not using uniflow will raise the pressure for most of the tank over uniflow and also give more margin.
p.s. I am thinking about soaking it evap-o-rust for a while, polishing it, and either tin or nickel plating it since it looks just as rough in real life as it does in the pictures.
p. p. s. - the Sullivan SS-4 (4-ounce slant tank) is a little under 1 3/8" wide, which is why I ended up using it although the cutoff characteritics are poor like almost all of them. I would also point out that, being a stickler for following directions, *this is also the tank shown on the original plans*.
Dave Hull
Dave T---I again point out that I ran this EXACT kind of test on one of my planes. I think I related this above. MM told us EXACTLY which two tanks he is comparing. You can look up the dimensions on the Brodak website. I did that. I also took two of those EXACT tanks out of my parts bin and compared them. There is a 1/4" difference in width, confirmed. My prior experiment proved to me that this quarter inch matters, and it matters for the reason given: that the uniflow will help compensate for the head height of fuel within the tank, BUT IT DOES NOTHING to compensate for the offset laterally between the tank pickup and the peehole in the spraybar. (This offset is THE determinant in the hydraulic grade line.) Because of the 3-G lateral forces during a typical sport/stunt flight, that quarter inch is effectively 3/4". Now imagine that you have your SuperWhatchamacallit .60 on a test stand and needled perfectly. And then I lowered your tank pickup (the whole tank) by 3/4".  I don't think anyone has the expectation that the engine will be running the same. I wouldn't.
All of this is based on details that MM gave for his setup using his spraybar lateral dimension.
These are not just random opinions. These are from actual tests. Can there be additional issues? Yes. As always. But an OS .25FP side-mounted and a stock venturi and spraybar will not pull uphill against 4-7/8" of effective hydraulic grade line. Not while maintaining a steady rpm. This has been TESTED. I suspect--but have not run the test--that an OS .25LA won't be any different. That is a legitimate question. Which is why I suggested that swapping the tanks between the two planes would be fairly convincing--although not COMPLETE proof that the issue is the tank width. And if he wanted to check the uniflow and pickup positions, he could do that without opening the tanks by some very careful, off the plane, filling and bleeding. Or, to brute force things, remove the back of the tank which I think is a poor second choice since you have to get it back together with no leaks and you are going to lose some tin-plating along the way and make it more rust-prone.
We hope to hear how Giffy works this out. I'd like to know.
Just my thoughts,
Dave H
Dennis Toth
I think one option is to open a tank hole in the outboard side of the profile fuse to slide the tank in that pocket would move it inboard ~1/2".
Best,   DennisT
Like Like x 1 Agree Agree x 1 View List
Brett Buck
Quote from: Dennis Toth on August 31, 2026, 11:04:12 AMI think one option is to open a tank hole in the outboard side of the profile fuse to slide the tank in that pocket would move it inboard ~1/2".
   That's an option, but it is usually a very bad option. It might solve the problem Motorman is having, but it also greatly weakens/softens the already weak/flimsy profile mount. Removing the doubler on one side effectively defeats the value of having doubler at all, since you change the structure from putting the doublers in tension and compression to just putting one of them in bending.
  With the 20FP, etc, it's *probably* OK, because it's runs pretty smoothly already, but any real shaker engines will usually have problems with vibration of the nose, with whatever durability or engine run problems it has. Ted Fancher's original "Doctor" suffered from that despite having balsa tripler and with it fiberglassed all the way back to the high point of the wing. It had the inner plywood doubler cut away to recess the tank (after we had already done the experiment described earlier with the Skyray and Coyote) to try to resolve the issue in this thread. But it caused a different issue where the front end was weakened enough to cause resonant vibration with the tank and tank mounts, which caused foaming at some points in the pattern. At one point we added stick-on weights to the *tank* to try to change the resonant frequencies with very good (i.e. predictable) results.
    This was a big problem with really shaky engines, like the 40-sized 4-strokes, and with some of the 4-break engines. As it turned out, and to no one's surprise, the 4-2 break engines didn't fly the airplane very well because of the lack of speed stability. The 4-strokes (running 4" of pitch at appropriate RPM) *would* pull the airplane very nicely when they were running right, but they would go audibly in and out of resonance as the fuel ran out. Might start out OK, go lean/foamy for 10 laps in the middle, then recover. Put a stick-on weight, and it might start out bad, then clear up and run out the tank correctly, that sort of thing.   To no one's surprise, smooth-running 2-strokes with low pitch/high revs pulled the airplane well, but had far fewer issues that were eventually resolved with some tank isolaters.
    Another important observation that we had also noticed with the other airplanes was that the elevator-only airplanes (Skyray, Doctor, Medic, etc)  was that the control response varies drastically with airspeed and airspeed variations, far more than flapped airplanes where you can barely tell. So you really don't want ancient 4-2 break engines on these elevator-only airplanes, because the control feel/sensitivity will be all over the place as the speed varies. For reference - the faster the airplane goes, the more sensitive it becomes to control effort. If anything, flapped airplanes do the opposite, but it barely changes in any case.
Quote from: Dave Hull on August 30, 2026, 06:15:47 PMI suspect--but have not run the test--that an OS .25LA won't be any different. That is a legitimate question. Which is why I suggested that swapping the tanks between the two planes would be fairly convincing--although not COMPLETE proof that the issue is the tank width. And if he wanted to check the uniflow and pickup positions, he could do that without opening the tanks by some very careful, off the plane, filling and bleeding. Or, to brute force things, remove the back of the tank which I think is a poor second choice since you have to get it back together with no leaks and you are going to lose some tin-plating along the way and make it more rust-prone.
Dave H
     I suggested the above mentioned tank swap early on, and that would have only taken a few minutes, and that would have told us a lot. It's till not too late to test fly that tank on the other airplane.
Motorman
Just came in from flying and first I would like to say, muffler pressure rocks. Going to explore that option on my other planes. It gave my flights the consistancy to discover what I think is the problem. I leaned  out the needle more and more each flight.
1st. too rich to do anything but soft climb and dives but ran the same the whole tank
2nd. leaner but still not enough power to do anything
3rd. lean enough to do some sketchy single loops. the run was steady no run away.
4th. Screwed down the needle some more and now have power to do sketchy wingovers and lazy eights. engine sounded the same the whole flight.
5th. Came in a few more clicks on the needle and pulled off an overhead eight it had good power towards the end but needed just a bit more in the beginning.
6th. Full two stroke but very rich, the slow fast spread was getting worse, too fast at the end but it was a gradual transition because of the muffler pressure.
My impression was I need more power from the engine or more drive from the prop so I can run the engine in more of a 4 stroke so it will stay cool and steady the whole flight. I think if the engine can keep cool as the tank goes from rich to lean it won't be as bad as having the engine heat up and make more power at the same time the tank is leaning out.
Does that make sense?
Brett Buck
Quote from: Motorman on August 31, 2026, 05:42:58 PMJust came in from flying and first I would like to say, muffler pressure rocks. Going to explore that option on my other planes. It gave my flights the consistancy to discover what I think is the problem. I leaned  out the needle more and more each flight.
   Yes, but you do not have it lean enough yet. Running just into a 2-stroke is the worst-case for fuel-feed pressure sensitivity. Set the needle by peaking it out in a 2-stroke, so one more click will cause it to sag. Then back it off maybe 3-4 clicks. Fly it, and see what happens in the maneuvers. If it is to "flat" in the maneuvers, open it one more click on the next flight. Keep doing that until you get about the right amount of pickup in the maneuvers.
    The intent is to run it just enough off peaked lean to allow some maneuver response. It will also help the beginning-> end issue.  The problem, as before, is that this is very likely to give you too much speed, because the engine is much too powerful for this size airplane.   Your best bet would be to depitch the 9-4 APC to 3.5 or lower, that will at least get you in the ballpark.
Dave Hull
Dan--Agreed. Go check the 4th post in this thread.
MM--Muffler pressure on tank raises the height of the hydraulic grade line at the pickup. Without it, you are fighting 4-7/8" of fuel rise with just the pumping effect of the crankcase through the venturi. That is the pressure at the bottom of a column of fuel 4-7/8" high. (Compare this, for example to the barometric pressure described by 29.92 inches of mercury. Similar concept.) But the peehole in the spraybar is still at some crazy hugely alternating pressure/vacuum level.*  And in between these points you still have 1.625" of dimensional "lift." Just adding pressure doesn't change that delta.
An interesting test on any new setup if you are running pressure is to start the engine and set it with the plane level. Then tilt the plane so that the outboard wingtip is about 72 degrees down but with the fuselage level. Note any change in run as it goes thru the tank. Don't tweak the needle. Now do the same thing without tweaking the needle but with the muffler pressure line pulled off. Whatever changes you identify with this test will be made THREE times worse in flight due to centripetal acceleration. The factor of three is not mysterious. It is a factor of the flight radius and lap time. So for example, at a 68' flight radius (lines, arm, half wingspan) and a 5.2 second lap time the factor is 3.1. It is far more sensitive to speed than radius.
I see a lot of planes that are set on the ground with everything level (not wrong) but when released and after accelerating to full speed in a quarter lap or so you can hear the engine change. There are several things happening, but one of them is definitely the change in fuel draw due to the centrifugal force on the fuel. Too many people simply call this "engine unloading due to the prop." That isn't the whole story. From your background in racing, you will recognize that a poor tank design, or just a poor tank position (hasn't been tank-tuned yet) will kill your setting on takeoff and you will die coming out of the pits. Same, same.
*--It is astonishing to think that air does NOT flow smoothly into a beautifully-shaped venturi past a spraybar in a nice, continuous fashion. Instead, the flow is valved by the crankshaft (front intake engines) about 167 times per SECOND with the engine running at 10,000 rpm. So the airflow MUST stop and start 167 times per second as it is sucked into the engine by crankcase pumping. This really hit home for me when watching a D-Speed ship startup (the starter guy gets a closer look than he really wants to) and seeing the absolute chaos in a venturi that looked the size of a shark's mouth. The fuel droplets that were "too big" bounced around inside the venturi in a chaotic fashion. I think this all worked itself out as the plane was launched really, really rich but after coming out of the dolly came on the pipe and the rpm went up hugely and all that fuel now was pumped more efficiently into the engine.
Motorman
Oh, guess I've been doing it backwards trying to run higher pitch props in a full 4 stroke.
Ok, I found the new Master Airscrew 9-4 measures 3.5 pitch and the inner stations are less so, it should be slower than the apc 9-4.
I also found a hop up I did. Opened up the muffler outlet and took out the baffle. I found a stock muffler and replaced the parts including the baffle. I'm hoping this will throttle it down some and make it quieter. Should give me a little more muffler presure too in theory.
Weather looks good tomorrow, we'll see how it goes.
MM :)
Brett Buck
Quote from: Motorman on September 01, 2026, 05:00:05 PMOh, guess I've been doing it backwards trying to run higher pitch props in a full 4 stroke.
    As per many previous posts - it *will not work without the stock muffler*, that is critical to the entire operation.
Like Like x 1 View List
Motorman
Got to go flying today with the changes I made. Bretts set up is nothing but the truth. I cranked the engine with the new stinger and lighter prop and I had to come in 1 whole turn to peak it out as expected.
I backed it off 1/4 turn from peak and launched. Ran great but a little fast, needs a 9-3. I had some balsa sticks to plug the venturi but I didn't use them. I opened the needle another 1/4 turn and launched again. Too slow but still ran steady.
Next flight I came in 1/8 turn and just like Goldylocks, just right. Yes, this is using the needle valve to control the speed but, once I was inside a 1/4 turn range with the enigne in a full two stroke the tank was very consistant.
I found out something about the OS NVA. It's finer than the S/T. You have to turn the knob more to get what you want. I like it.
Thanks for the great advise Brett.
MM :)
Brett Buck
Quote from: Motorman on September 07, 2026, 01:52:35 PMNext flight I came in 1/8 turn and just like Goldylocks, just right. Yes, this is using the needle valve to control the speed but, once I was inside a 1/4 turn range with the enigne in a full two stroke the tank was very consistant.
    Great! Glad its working for you! Using the needle valve to control the speed is OK in the small and when you are near a stable operating point. But you can't take a 1 hp engine and make it into a 1/4 HP engine by simplying screwing the needle valve out.
The *weakness* in the arrangement is that the needle valve changes the power AND the engine response. The richer you run it, the more response you get in-flight. So getting both of those right at the same time and with some day-to-day robustness is pretty complicated if you really try to optimize. Based on dozens of examples exactly like yours down to the details, my guess is that you are still a bit on the rich side and probably getting more action out the engine that is ideal. Take a APC 9-4 and depitch it to 3.75, this will allow you to run it leaner and smooth it out some more.
   As far as I can tell, it is just luck that the 20FP (and the last version of the 25LA) just happened to hit this sweet spot at the required power levels *exactly as they come out of the box*, as you found, absolutely ideal just exactly like it left the factory. The 25FP isn's as good, it has somewhat excessive power for the intended applications at the same "sweet spot" and most attempts to "fix it" make it worse. Still *pretty good* but not as good as the 20FP and 25LA.
    The OS needle is better than the ST for several reasons - it's finer (combination of thread pitch and taper), it supports the needle much better by bearing on the shaft until the taper starts (instead of pinching it at the end of the ST collet) and it *has clicks*, which makes it far easier to avoid inconclusive micro-tweaks. The rear needle on the 25LA is a lot more touchy and one click is bordering on too much change, the front needle is very nice.
   So I think you can see why I recommend absolutely dead stock setup. You can make it work with other setups and systems, maybe. We tried large numbers of them, and even many/most of my buddies have gone well off the reservation - which has caused them grief many times, although they usually figure it out (you might note some of my flying buddies are, shall we say, "highly accomplished"). But I never found any more stable and even more, never found any setups that were more *consistent* from example-to-example.
Motorman
Ok, going to apply the same logic to my Ringmaster. Looking at the engine it is not box stock. Metal back plate, Brain Gardner abc, socket head cap screws, 1/4 venturi, tiger nva, stinger on the muffler is drilled out with no baffle.
 I put a piece of aluminum tubing in the stinger with JB weld to get it close to the stock size. I put on a MAS 9x4 semitar which is a 3 pitch and I launched with the needle pretty fat. Plane flew great but I wanted a little more speed.
 Cranked the needle in some and launched. Flew good for a few laps then turned into a speed ship and cooked down bad at the end. Thank goodness for abc which will expand the sleeve to save the cylinder, the engine was ok.
Back to the lab. I put a piece of 1/4" tubing in the ventui and burnished the ends to match the taper, cut out the cross hole and de-burred. venturi is now .218" a bit smaller than the stock 6mm.
What I really need is the internal baffle for the muffler. I looked all over but I think it went to the scrap yard during some basement clean out down sizing. Well, I cut a disk out of tin stock and punched a 5/16 hole in it. Normally it would rattle around in there but I ground the shoulder and cooling fins off the rear cone so it would slide all the way in.
Tank is a Brodak 3 oz wide wedge converted for muffler pressure. Seems to be working good. If the engine still wants to run away after the de-tuning changes I'm not opposed to adding another head shim but hoping I don't have to disturb the head because the piston/sleeve fit is so good right now.
Hoping to fly tomorrow.
MM :)
Quote from: Motorman on September 15, 2026, 05:25:44 PMOk, going to apply the same logic to my Ringmaster. Looking at the engine it is not box stock. Metal back plate, Brain Gardner abc, socket head cap screws, 1/4 venturi, tiger nva, stinger on the muffler is drilled out with no baffle.
MM :)
    The baffle for the 2030 muffler is cone shaped, and sits in front of the stinger a good distance. There really is significant difference between the 842 ( I think that's the number) and the 2030. I don't think a flat sheet metal baffle in the older mufflers will have the same effect.
Motorman
I stole the muffler off the Shark 402 and put it on the Ringmaster. That Shark is a crashed up flea market rescue and it's heavy enough the Ringmaster actually flys better so it gets the good muffler.
MM :)
Steve Helmick
#41
Quote from: Motorman on August 29, 2026, 07:42:15 AMOk, but check this out. On the Ringmaster the spraybar is 1/2" from the fuselage and the pick up tube is 2-3/16" because, I had to kick the back of the tank out 3/16" to get a clean cut off. So maybe the shape of the tank plays a big role or maybe the Ringmaster just flys nose out too much.
Has anyone made a tank that's thinner on the inboard side then expands out before the coffin corner? Might be interesting.
The Ringmaster yaws out too much. OR, the tank has the pickup tube poorly located in some way. Don't forget about brass tubing getting perforated  by corrosion and causing weirdness. Steve
Edit: Just re-read some MM posts. The .218" restrictor is way smaller than it should be for a .25, but I don't recall seeing how big the spraybar is. I didn't like the stock .25LA rear NV, and violated the threads to put in a 4mm spraybar. Randy Smith's spraybar assemblies are that awesome. I drilled out my .25LA factory venturi to .271". Ran fine, but I didn't like the clicker-type K&B assembly I put in it.
Brett Buck
Quote from: Steve Helmick on September 21, 2026, 04:54:41 PMThe Ringmaster yaws out too much. OR, the tank has the pickup tube poorly located in some way. Don't forget about brass tubing getting perforated  by corrosion and causing weirdness. Steve
   I think you are missing large portions of this thread - Motorman worked himself back to a bone-stock engine with an appropriate tank, and it worked as expected. Now he is trying the same with his Ringmaster (which we all think will probably be really fast) and is looking for his missing parts.
Motorman
Got to fly the Ringmaster with the new muffler and .218" venturi. With the MAS 9x4 Semitar (3 pitch) it had no drive above 45 degrees, lines go slack. I put on an APC 9x4 (true 4 pitch) and richened the needle a bit. It was better but still could not do a vertical eight or more than one sketchy overhead eight. Engine was working like it should but, just not enough power. Towards the end of the flight it overheated and sagged off like it was over propped. I'm definitly taking the venturi restricter out for the fly-a-thon. Got to get a stock 6mm venturi and a black MAS 9x4 GF series prop (3.5 pitch).
MM :)
Brett Buck
Quote from: Motorman on October 01, 2026, 06:18:37 PMGot to fly the Ringmaster with the new muffler and .218" venturi. With the MAS 9x4 Semitar (3 pitch) it had no drive above 45 degrees, lines go slack. I put on an APC 9x4 (true 4 pitch) and richened the needle a bit. It was better but still could not do a vertical eight or more than one sketchy overhead eight. Engine was working like it should but, just not enough power. Towards the end of the flight it overheated and sagged off like it was over propped. I'm definitly taking the venturi restricter out for the fly-a-thon. Got to get a stock 6mm venturi and a black MAS 9x4 GF series prop (3.5 pitch).
MM :)
   The stock venturi is 6.6 "mm" or .260 measured as a true diameter. Not 6 "mm" or .236.
   Relative choke area:
.260 - 100%
.236 - 72%
.218 - 52%
    Which one you want to try to tame it down enough to fly a Ringmaster at a reasonable but fast speed, I don't know, but .236 is not a bad starting point.
Dennis Toth
Sounds like you need the bigger venturi as Brett suggested, also what %N, lap time/line length are you at? I think a little extra nitro can't hurt. One last point for the Ringmaster, use a bit of engine off-set (3 deg ish) will help with the overheads and vertical 8's. If it's going to slow when you get up top you can hit the Netzeband wall where there isn't enough line tension to keep the elevator in the desired position and it gets blown down some, this opens up the top loop and you end up at 10' instead of 30' to do the bottom inside. Also, make sure the leadout position is correct and not too far forward which would also hurt the up top performance.
Best,    DennisT
Brett Buck
#46
Quote from: Dennis Toth on October 02, 2026, 07:40:18 AMSounds like you need the bigger venturi as Brett suggested, also what %N, lap time/line length are you at? I think a little extra nitro can't hurt.
     Just like the other thread - the stock venturi is .260" (true) (or about .257 (calipers)), which is *6.6 "mm"* - not any other size. As far as I know there has never been any other size for either the 20/25FP or 25LA. and all those I have ever measured were +-.0005" of that.  Everything I ever said about the engine in print was using the stock .257 venturi (although I have experimented and seen other experiment with other sizes and "Accidental" other sizes using incorrect spraybars).
    He currently, apparently, has a .218 venturi that he got somewhere. Again I am not the venturi police, but this is *drastically smaller*, with around 1/2 the choke area of the stock unit, and very roughly half the potential power. Not surprisingly, this isn't enough for his Ringmaster and he is having to practically melt it and still not having enough power/speed to fly properly.
   He is planning on getting another undersize venturi - .236 or 6 "mm". I recently noticed that someone is selling these on eBay and sort of implying they are "stock", which the are not, at least unless I have been missing it for 30+ years. This is still very small compared to the stock venturi with about 72% the choke area/power.
    This latter venturi has a chance, because, after many experiments, we know that the Ringmaster will be drastically too fast with the stock 20FP or 25LA engine running properly (100% power, about 3.8 second laps on 60 foot lines) , and we know it is too slow with the .218 venturi (unknown but obviously too slow, maybe 5.3-5.5, and probably going over the top lean in the maneuvers as he it tweaking it within an inch of its life to get as much power).
    The 6 "mm" /.236 venturi is about halfway between the stocker and the .218 and will give about 72% of the stock power. This very roughly splits the difference, which sounds about right in terms of speed.  It also corresponds very roughly to what you would expect with a stock *15FP* which I know from experiment is about right for a Ringmaster - it's about 71% of the displacement and notionally the power (2.5 "cc"/3.5 "cc") of a stock 20FP.
    So the aftermarket 6 "mm"/.236 venturi sounds about right for a 20FP or 25LA on a Ringmaster.
    I would also note that these are absolutely enormous jumps in venturi size by stunt standards. I usually use variations of about .005" per "step" on much larger engines, plenty enough to make a difference but not big enough to jump over the right value. Going from a stock venturi to a .218 venturi is more than 8 "steps" and not surprisingly jumped from "way too big" to "way too small". The new proposed 6 "mm"/.236 venturi is about 5 steps smaller.
  If I had guessed ahead of time, I would have tried something about 4 "steps" smaller, so I would expect that -5 "steps" will be in the ballpark, at least close enough to start experimenting with +-a step at a time to optimize it. By optimizing it, I mean, it gives a workable overall speed with a medium 2-stroke setting, and picks up to a hard 2-stroke in the maneuvers. One you have that, you tweak it 1 step at a time until you get the most beneficial range of "medium" to "hard" to maneuver.
    I know this is long and I have taken very great pains to spell out every step, to the point of pedantry. This is because this is an independent experiment (i.e. not just me dispensing directions, and someone else working through the process) that illustrates the general process behind the very simplest part of setting up engines - getting the power in a workable range to begin with. This is done by picking a venturi that is in the ballpark, this is the first step. This is a particularly easy case, because that's going to be *all* that is required - many people have already found that once you get the power about right, the rest of the engine setup is also about right. That's why I recommend these engines over all the others.
p.s. I would also strongly recommend changing *one thing at a time* instead of multiple - like the venturi AND prop AND nitro. That is a formula for losing track of the problem. I would stick with the 9-4 APC since I know for certain it is going to work out better in the long run and is both easily available and cheap. Similarly with 10%. I have run anything from 5% to 20%, 10 is way better than 5 in terms of needling and run stability, and 15 and 20 provide negligible additional benefit and YS20/20 is something like $10 a gallon more expensive. Once the system is working reasonably well with a proper venturi (either .236, 241, or whatever), check the in-flight response over 20ish flights in varying conditions, then see what else might be needed to optimize it. Ultimately it is a Ringmaster with an engine capable of extreme overkill power - how optimal does it need to be?
Motorman
I'm dragging too much line .015 x 60. If you could see my field you'd understand why I can't risk a fly away. Besides I bought a 1000' spool of this stuff and it's just a sport plane.
I did crash it once and I glued the nose back on with some out thrust by accident so, dumb luck was working for me on that one.
The venturi is one I made at .250" when I still had my venturi making machine. I know .218" was a big jump down but I'm working with tubing sizes here. I'll have to check part numbers on the stock one for this engine.
Fly-A-Thon tomorrow.
Brett Buck
#48
OS stock part number for the venturi is 22312000.
https://stunthanger.com/smf/open-forum/problem-engines/msg670926/#msg670926
p.s. .015x60 is absolutely standard setup for "modern-engine" Ringmasters. Any shorter and you will be screwing yourself into the ground when you get the engine running right. Speed is the problem - that is, *too much speed*.  Too short and you will tend to get into "coffin corners" due to the limited cornering capability. It's way better than with a Fox  but it's still far from an Impact
Brett Buck
And courtesy Ryan Taylor, the templates for the tank shown earlier:
https://clstunt.us/t/l-1-8202.html
  Note that this was from *22 years ago* and you can already see how much grief I got - in this case, it was a response to Leonard Neumann after he said the venturi was "way too large" - which is is not, for the intended applications - because it didn't go proportionally with the displacement in his horrific "venturi chart".
