CLICK HERE--><--CLICK HERE
Smaller Tank Worse
Started by Motorman, October 19, 2026, 04:00:12 PM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Motorman
I have a 3oz. wide wedge tank that's 2" wide. I only put 2oz. in it so, the fuel goes from 1-3/8" to zero with one third the tank being dead space
If I put a 2oz medium wedge tank on it would be 1-3/4" wide. So, when I fill it, the fuel would go from 1-3/4" to zero.
So, the smaller tank would go from rich to lean more than the bigger tank?
MM :)
bill bischoff
Only if they're both standard vented instead of uniflow. Either way, the fact the pickups are different distances from the fuselage will factor into it as well. I'm assuming we're talking about a profile model.
Brett Buck
Quote from: Motorman on October 19, 2026, 04:00:12 PMI have a 3oz. wide wedge tank that's 2" wide. I only put 2oz. in it so, the fuel goes from 1-3/8" to zero with one third the tank being dead space
MM :)
  The variation from beginning to end is a function of the change in the fuel depth over the flight. The absolute pressure is a function of the variation, and the "width" of the tank, that is, how far the fuel has to be pulled inboard (or pushed outboard) against centrifugal force.
