CLICK HERE--><--CLICK HERE
Never Had Any Luck With Oval Wedge Tanks.
Started by Motorman, August 27, 2026, 05:20:59 PM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Motorman
I have 2 planes, a Ring Master and a Shark 402. Both have OS LA25 box stock same apc 9-4 and 3oz uniflow tank. The difference is the 402 has an oval shaped wedge tank and the Ringmaster has a rectangular Brodak tank. Ringmaster flies great but the Shark gets to the square 8 then leans out and runs away. Is there something about the oval that makes it run rich to lean more severely? The Brodak tank is 1" thick all the way across, the oval is 1.400" on the inboard side and goes to a point. Maybe that's what does it?
MM :)
Colin McRae
Are you talking about a Brodak 'stock' oval profile uniflow tank? On the Brodak stock tank, the fuel pickup is on the top of the tank. Not good IMO.
I have had good luck with the Brodak oval profile uniflow tank, but I have, on special order, had Brodak custom relocate the fuel pickup tube to the bottom of the tank. The fuel pickup tubing routing is much more efficient on a profile model and eliminates any 'high points' on the fuel line where air bubbles might be trapped.
Also, I normally use their wide wedge tank but use the oval profile tank if I don't have enough room for the wide wedge tank.
Colin
Brett Buck
Quote from: Motorman on August 27, 2026, 05:20:59 PMI have 2 planes, a Ring Master and a Shark 402. Both have OS LA25 box stock same apc 9-4 and 3oz uniflow tank. The difference is the 402 has an oval shaped wedge tank and the Ringmaster has a rectangular Brodak tank. Ringmaster flies great but the Shark gets to the square 8 then leans out and runs away. Is there something about the oval that makes it run rich to lean more severely? The Brodak tank is 1" thick all the way across, the oval is 1.400" on the inboard side and goes to a point. Maybe that's what does it?
  If this is the old teardrop-shaped tanks, they are generally too wide to work with the stock venturi. The tank wants to be no more than about 1.5" wide from the base to the peak, 1.75 is pushing it. Alternatives are to mount it inboard a la Dirty Dan, get a Sullivan clunk tank with the wide side up against the fuse, or a narrower conventional tank.
Dave Hull
You didn't say if you were running tank pressure. If not, how good is your forward-facing vent? Is it in clean air?
The load on the engine should be pretty similar since the planes are pretty close in terms of drag. (Same span) Is the Shark heavier?
I know from testing that a standard vent oval is worse than a standard vent wide wedge in terms of change in fuel draw and changed the engine run on even a very tolerant engine. (Tested on a Flite Streak.) If you add uniflow, it should get better. If you add muffler pressure, it should even it out some more.
The oval is both wider and deeper and neither helps with uniformity of fuel flow. Even if the uniflow "cancels out" the pressure head change as the free surface of the fuel moves outboard (tilted around 18 degrees from vertical) with fuel burn, you still have the pickup in the tank another 1/4" outboard compared to the wide wedge. (BH-590 vs. wide wedge). So the engine is forced to draw harder.
I always think in terms of the "size of the sweet spot."  Some engines have a wide sweet spot (OS .46LA) and others do not. For those that do not, small changes in the setup can make a lot of difference.
While it seems that the two examples are so similar that they should run the same, but there are actually a lot of differences. But you have a great opportunity to swap the engines and see if the problem follows the engine or the plane. Swap the tanks and see if the problem follows the tank.
Maybe you can get a special dispensation to do the square eights after the clover, and avoid most of the runaway...?  (Tongue firmly in cheek....)
Colin McRae
Quote from: Brett Buck on August 27, 2026, 08:43:57 PMIf this is the old teardrop-shaped tanks, they are generally too wide to work with the stock venturi. The tank wants to be no more than about 1.5" wide from the base to the peak, 1.75 is pushing it. Alternatives are to mount it inboard a la Dirty Dan, get a Sullivan clunk tank with the wide side up against the fuse, or a narrower conventional tank.
A few data points for info.
Brodak's stock tank widths:
wide wedge 2" to base
oval profile 2.25" to base
medium wedge 1.75" to base
Colin
  Try swapping them tanks between the two airplanes and see if the proble goes where the tank goes. If that tank is too wide and the pickup is too far outboard, the enginexwill go leaner invthe air because the fuel has to go against centrifugal force. Rework the tank and have the tube run as  lose to the inboard side as you can and have it exit the front if there is room or from the bottom about 1/2" from the inboard side. I have had that work for me when needed.
Brett Buck
Quote from: Colin McRae on August 28, 2026, 09:54:30 AMoval profile 2.25" to base
   Almost no chance, there may be some lucky combinations that work but that is too far to draw fuel 2" uphill against 2 1/2 or 3 gs. The symptoms are perfectly consistent with that, assuming it is on suction. I would expect it to diverge right after launch if uniflow.
Motorman
The uniflow vent is more inboard on the shark tank (yellow caps), does this make a difference?
Brett Buck
Quote from: Motorman on August 28, 2026, 03:33:14 PMThe uniflow vent is more inboard on the shark tank (yellow caps), does this make a difference?
   Where does the uniflow terminate inside the tank? Where it comes out makes no real difference.
   But, given that I had the same thing happen on the 20FP, I would recommend you plug the uniflow vent, and put muffler pressure into the overflow. And if it all possible, use a narrower tank so that hydrostatic pressure drop from the tank to the engine is reduced, or put it inboard so the hydrostatic pressure rise helps you.
    My baseline setup is a Sullivan SS-4 clunk tank, flat side set up against the fuselage, with pressure into the overflow.
Motorman
I put the uniflow tube in the middle of the tank outboard side. I guess that won't matter with muffler pressure going in the over flow line. I think I still have my pressure fitting so, I'll give it a try.
The Shark is heavier with a thicker wing. I guess that extra load would put the engine on/over the edge? Don't know how to adjust for that. Depitch the prop tips, bigger venturi?
Venturi is 6mm and the OS sparybar I think is 3.5mm. Sprybar sits 5/8" from the fuselage. I found a 3oz Brodak medium wedge tank but I'll have to re-plumb it. Pick  up sits 1-3/4" off the fuselage. Best I can do without going to a Fox tank which is also a bad luck tank for me.
MM :)
Brett Buck
Quote from: Motorman on August 28, 2026, 08:31:54 PMI put the uniflow tube in the middle of the tank outboard side.
  I think you mean fore/aft position. I meant lateral position, left/right, inboard/outboard/
Dave Hull
"The uniflow vent is more inboard on the shark tank (yellow caps), does this make a difference?"
It makes no difference in terms of hydraulic grade line. But if you are NOT running muffler pressure, and the open uniflow vent is in a "bad air" location, that can affect the run.
But your real, known problem that we've mentioned several times is that the wider the tank is, and the farther the fuel pickup is from the fuselage, the more effort it takes to draw fuel "uphill" to the hole in the spraybar. According to your dimensions, 2.25" - .625" = 1.625" is the height you are expecting the venturi to draw the fuel uphill against about 3-G's of centrifugal force. In terms of work, this could be described as a "lift height" of almost 5 inches in a 1-G environment. Comparing to your other tank, the wide wedge buys you back .25" of reduced "lift height." I have found that significant with some engines. If you can use a medium wedge it buys you back another .25".
Dave_Trible
I suspect it's about the interior location of the end of the uniflow tube.   If the tank is working correctly air is sent (or pulled) into the tank and bubbles up into the air pocket, maintaining a small pressure head pushing the fuel out.  When suddenly the end of the tube is uncovered-no longer submerged- the pressure head escapes and fuel pressure is lost. This is when the engine goes lean.  It sounds like the end of your uniflow stops somewhere in the middle of the tank or wherever the fuel consumption/square eights happen and it takes off.  I've not seen the inside of these tanks but if you pulled the back cap off I'm pretty sure that's what you will see.  For some reason these tanks must be made differently.  There should be no significance in the edge shape of these tanks in relation to what you are experiencing .    The exact opposite can also happen-engine goes rich- IF the inflow inlet isn't big enough or is somehow restricting the air flow and not allowing enough air in.  Here it might gradually go more lean through the flight as the engine tries to pull fuel until the vacuum is released and fuel flows freely just before it runs out of fuel.
Motorman
Ok, but check this out. On the Ringmaster the spraybar is 1/2" from the fuselage and the pick up tube is 2-3/16" because, I had to kick the back of the tank out 3/16" to get a clean cut off. So maybe the shape of the tank plays a big role or maybe the Ringmaster just flys nose out too much.
Has anyone made a tank that's thinner on the inboard side then expands out before the coffin corner? Might be interesting.
Dave_Trible
Quote from: Motorman on August 29, 2026, 07:42:15 AMOk, but check this out. On the Ringmaster the spraybar is 1/2" from the fuselage and the pick up tube is 2-3/16" because, I had to kick the back of the tank out 3/16" to get a clean cut off. So maybe the shape of the tank plays a big role or maybe the Ringmaster just flys nose out too much.
I don't think this is different than has been done on profiles for a long time.  Profiles have never been ideal engine run platforms to begin with but even in full - bodied airplanes we've used 2" wide tanks forever with the pickup offset to the outboard and pulling maybe 8-9" from the back corner.  You aren't pulling half that and aren't offset really any more to speak of. Your venturi is offset 1/2" to the outboard on a profile and not on centerline like an upright or inverted setup.  I don't think this is creating your issue.
Dave_Trible
Dave_Trible
This is the tank on my profile airplane.  Rectangle tank with pinched rear corner.  That back corner is almost 2 3/8" out from the fuse.
Brett Buck
Quote from: Dave_Trible on August 29, 2026, 08:32:36 AMI don't think this is different than has been done on profiles for a long time.  Profiles have never been ideal engine run platforms to begin with but even in full - bodied airplanes we've used 2" wide tanks forever with the pickup offset to the outboard and pulling maybe 8-9" from the back corner.  You aren't pulling half that and aren't offset really any more to speak of. Your venturi is offset 1/2" to the outboard on a profile and not on centerline like an upright or inverted setup.  I don't think this is creating your issue.
  I am not sure what you are trying to demonstrate or explain here. The issue is *pulling fuel against centrifugal force* which has the effect of reducing the pressure at the pickup in proportion to the width of the tank, not how far it is to the rear of the tank.  It's much worse on profiles because the tank hangs out much further to the outside. On full fuse airplanes it is at worst about 1" or a little more (also depending on the width), and that is a huge reason why they run better. This is also why an inboard fuel tank solves the problem - instead of a loss of pressure due to hydrostatic effects, it actually increases the pressure over the tank outlet pressure.
  I am also not sure why you are showing other engines - you can make an engine pull fuel 6" with perfect operation if the venturi is small enough. The 20/25FP, 25LA with the stock parts has only so much fuel draw, it will not pull fuel against 2.5 or 3Gs 2+inches uphill. We very extensively experimented with exactly this effect, trying to determine the maximum usable tank width, which was about 1 3/4, any more than that, and it tended to do exactly what he is describing (particularly on uniflow). Not every time, but often enough that it is *not recommended*.  The alternative - run a smaller venturi (or the f'ing ST spraybar) kills all the power.
  This is also a function of the prop diameter - because a larger prop with the same pitch has to turn slower to get the same airspeed, it also sucks fuel more weakly, exacerbating the problem. That's why you are supposed to use an *APC 9-4* and nothing else, at least to start, because it is inefficient enough to allow a usable RPM without generating excessive speed. If you use a 10-4, or worse, a 10-6 (either of which the engine is otherwise perfectly capable of turning without trouble), either the speed will be excessive or the RPM will be too low, and it will not suck fuel properly on a profile mount.
    Hence the admonition in in every single post I have ever made about how to set up the 20FP, etc - use suction venting, attach the pressure tap to the suction vent, do not use uniflow, and make the outboard edge of the tank no more than 1.75" from the bottom of the mounting lugs
and preferably less.
  Motorman has, apparently, a tank around 2.25" wide and is running some sort of uniflow (which I think probably goes to the far outboard, although that is unclear) and no pressure. If I borrow back the original Skyray/25LA, set it up like that, mine will go hard lean at about the same point his does on every single flight. I had it that way, that is exactly what it did, same with Ted's Shoestring - and everybody else who tried it, failed, too. The solution is to get a much narrower tank or mount it inboard as Dirty Dan suggested 20 years ago.
bob whitney
how much difference dose the size of the exit hole in the spray bar make
rad racer
Colin McRae
#19
Your oval profile uniflow tank is Brodak stock which has the fuel pickup on the top of the tank. IMO there are 2 significant issues with this arrangement. (1) Assuming your spray bar inlet is on the bottom of the engine, the fuel tubing goes up and down and up on its way to the spray bar inlet. The high point in the routing allows for air to be trapped. (2) The fuel supply tubing is way longer than it needs to be.
This pic is the same Brodak tank on a Skyray 35 with OS 25 LA (w/ APC 9-4 sport prop), however, I had Brodak custom relocate the fuel pickup to the bottom of the tank. A straight shot to the spray bar inlet and very short. I have 3 different profile models with this same basic arrangement, and I have not noticed any significant engine run issues.
If your 25 LA uses the stock remote needle setup and the fuel pickup on the top of the tank, there will still be a high point in the fuel tubing. I prefer the conventional front NVA setup.
Colin
Dave Hull
Bob,
The peehole in the spraybar shouldn't make much difference as long as the needle will allow you to throttle the engine up and down thru the "usable range" of rpm. The reason is that the peehole is NOT supposed to be the smallest restriction in the path--the clearance between the needle and the needle seat is.
That said, if the hole WAS too small, then there would be excessive restriction where you don't want it. But you can check the setup easily: start the engine and open the needle slowly until it slows down so much it dies. You just proved that the needle seat clearance is working and that the pee hole is not too small.
The only needle valve assembly that I have personally run across with "too small a hole" was a batch I bought from Henry years ago. In fact, they had NO peehole at all. So I drilled one. And they all worked fine.....
Brett Buck
Quote from: bob whitney on August 29, 2026, 01:37:35 PMhow much difference dose the size of the exit hole in the spray bar make
   On these small engines, very little. You do have to concern yourself with fuel flow restrictions on large engines (61 and up), sometimes, with subtle effects.
   Using excess, or excessively heavy oil, can be a bigger and easier to deal with problem. Stunt people tend to throw large amounts of castor oil at every engine problem, this was maybe a good idea with ancient engines but can be a complete disaster with modern engines. You do not need it to keep the piston/liner alive but it does increase the fuel viscosity and make it harder to draw.
Motorman
The OS NVA has a tiny hole and, racing a Brodak LA25 Foxberg set up, the hole needed to be opened up or the engine was hard to needle. Don't remember the number but it wasn't much, not as big as SuperTigre.
I don't think this is needed in stunt/sport because the needle is open alot more but it wouldn't hurt anything.
MM :)
Dave_Trible
Quote from: Brett Buck on August 29, 2026, 12:52:51 PMI am not sure what you are trying to demonstrate or explain here. The issue is *pulling fuel against centrifugal force* which has the effect of reducing the pressure at the pickup in proportion to the width of the tank, not how far it is to the rear of the tank.  It's much worse on profiles because the tank hangs out much further to the outside. On full fuse airplanes it is at worst about 1" or a little more (also depending on the width), and that is a huge reason why they run better. This is also why an inboard fuel tank solves the problem - instead of a loss of pressure due to hydrostatic effects, it actually increases the pressure over the tank outlet pressure.
Well the initial question was whether the shape of the tank was causing the run problems.  As much as I can see from the photo the oval tank doesn't appear hardly any wider than the regular wedge he has no trouble with.  True I don't have experience with these smaller motors on profiles.  Might be they are harder to deal with in this respect but in this case I'm not seeing much difference between the two tanks.  My tanks throw another shape into the mix and yet I believe does nothing to create the problem of going lean half way through the run.  I think it is uniflow placement inside.  I do think shape will have more effect if the tank is thicker as it might have more pressure variation full to empty as the fuel moves around in the tank.  I can recall an old Veco fuel tank designed for profile airplanes that was really tall but not very wide-shaped like an old barn laid on it's side.  We didn't have uniflow in those days.  I'm sure we must have had one or two of these but can't remember anything about the run-probably wouldn't even know the difference back then.  On suction they all ran progressively leaner as the tank ran dry.  The two tanks he is using are really not drastically different in overall height so I'd discount that for this problem.  Shape-wise these two should function nearly the same in my estimation.
Quote from: Dave_Trible on August 30, 2026, 07:12:57 AMWell the initial question was whether the shape of the tank was causing the run problems.  As much as I can see from the photo the oval tank doesn't appear hardly any wider than the regular wedge he has no trouble with.  True I don't have experience with these smaller motors on profiles.  Might be they are harder to deal with in this respect but in this case I'm not seeing much difference between the two tanks.  My tanks throw another shape into the mix and yet I believe does nothing to create the problem of going lean half way through the run.  I think it is uniflow placement inside.  I do think shape will have more effect if the tank is thicker as it might have more pressure variation full to empty as the fuel moves around in the tank.  I can recall an old Veco fuel tank designed for profile airplanes that was really tall but not very wide-shaped like an old barn laid on it's side.  We didn't have uniflow in those days.  I'm sure we must have had one or two of these but can't remember anything about the run-probably wouldn't even know the difference back then.  On suction they all ran progressively leaner as the tank ran dry.  The two tanks he is using are really not drastically different in overall height so I'd discount that for this problem.  Shape-wise these two should function nearly the same in my estimation.
     I would agree that, just from my experience with similar tanks, that the size and shape isn't the issue. I would still suggest swapping the tanks between the airplanes and see if the problem follows the tank, then if it does you know where to start. If it DOESN"T, and the 402 still leans out at about the same point in the pattern, then it could be the airplane and it could be yawing enough to make the fuelload run away from the pick up. Shim the back of the tank out about 3/16" and see what happens. I have experienced the "wide tank syndrome" that Brett mentions and I  been playing with the tubing routing on several tanks over time and came to the conclusion that the tubing route can make a difference. I have taken wide tanks and ran the tube towards the mounting side and then exit the front of the tank or from the bottom at a spot that is convenient for that engine installation. On some profiles, you are really limited on space. I make the tank as thick and I think IO can get away with, then as wide as necessary to get the volume I need. Then I route the fill/uniflow, overflow and pick up/feed tube accordingly to make routing the fuel line as efficient as possible with as few, or no kinks or bends in the feed line. That means going underneath the engine somewhere between the mounting lugs and the exhaust. It's worth the extra time and trouble to do that. On the tanks in question, if they have never been taken apart to examine them, what are you waiting for?? Especially the problem tank. Open it up and look for anything out of the ordinary, and if nothing is obvious, move the pick up to exit from the bottom of the tank and closer to the side that is against the fuselage. If it's not working now, you have nothing  to lose.
