  • June 20, 2025, 11:38:50 PM
Author Topic: OS Max 35 S venturi  (Read 1269 times)
Offline Robert Zambelli
OS Max 35 S venturi
« on: April 02, 2019, 09:08:33 PM »
Hi, Gents.
I lost my venturi for my 35 S and I made a new one.
What is the proper inside bore?
I'm using the standard OS NVA.
THANKS, Bob Z.
Offline Mark Messmer
Re: OS Max 35 S venturi
« Reply #1 on: April 03, 2019, 06:09:41 AM »
I use around a .281 or so on mine .
« Reply #2 on: April 04, 2019, 03:03:28 PM »
Hi, Gents.
THANKS, Bob Z.
Depends  If you are  using  the stock  703  muffler  then use a  .305 restrictor, if you are using an open tube muffler  or  tongue  muffler  then use a  .281  restrictor
