Is there any rule of thumb for needle setting when flying the same plane several times in a row. My first flight the motor always runs the best and then the second and third flights are not as powerful. Do you lean or richen the needle more with each consecutive flight?Also have been using Sig 10% fuel during the summer should I change to a different nitro percentage when the weather is cold? What is the rule of them for deciding nitro percents? This is on an OS 25 LA with the venturi and back plate modifications made per members of this site.
Unless the conditions are changing or you have some sort of cooling issue, you shouldn't have to change the needle on consecutive flights. What can happen, however, if you misuse a tach by continually trying to hit a "number", you could have problems. Some airplanes needle consistently on the ground on a second flight, and some don't. Mine typically doesn't. We routinely fly 2 flights back-to-back when practicing, to save time moving airplanes on and off the circle. Mine will run ""normally" on the first flight, but on the second (with no attempt to let it cool, just long enough to fill it up), it will start and run quite a bit faster/leaner. It will stay that way until about the 3rd or 4th lap, as the in-air cooling drives it back to equilibrium. If I was to try taching it to a fixed number on the second flight, I would end up opening the needle to slow it down, then when I took off it would slow down a lot and feel weak. If I need a change on the second flight, I will tweak it open-loop (i.e. just open or close it about what I thought it needed) without paying attention to what it sounds like.
Of course as the air temperature or density changes over the course of the day, you will likely have to chase the needle up and down to keep it constant. Typically, you will have to close the needle to keep the same speed since it usually warms up over the course of the day. It's not a problem if you are just out there practicing all day, but at a contest, this can be an issue. At this years TT, I was good until the sun came out and the temp went up drastically. I knew to tweak it up, but since I had flown about 20 flights all year, I guessed wrong on how much, didn't do it enough, and ended up with a functional but not very positive speed - and then I not only got off the team, Bill even beat me for #4. Very frustrating but that was an example of not being fully engaged and it costing me - in the *hardest contest in the world*, you can't overcome that.
As the temperature changes, I change the nitro and pretty much nothing else. I think changing it until you get the right run time is a good start. If you run 6:30 on 10%, and it gets cold, and you start running shorter, lower the nitro until the same volume gets you about the same run time. Some people actually ONLY change the nitro and not the needle as the day goes along. It's easy to mix fractional percentages in the syringe - if you want 12.5%, take 2.5 oz of 15% and 2.5 oz of 10%, shake it up, and put it in there.
