  • July 07, 2025, 07:14:07 PM
Author Topic: Needed: Operating suggestions for a Broback .25.  (Read 1222 times)
Offline frank mccune
« on: July 11, 2014, 11:34:49 AM »
     Hi All:
     I would like to know how I should run this engine for stunt use.
     I have been running a 9X4 prop and setting the engine to run at a very fast 4 cycle on take off.  I am of the beleif that this is how this engine should be run.  In the air it beaks into a very wet 2 cycle and stays there during the entire flight.  I am running a Uniflow tank that works very well.
    I think that I have read that these engines should be operated on the lean side to enable them to run at the correct clearences due to their construction materials.  Can these engines be damaged by running too lean?
    I am running 11,11 oil, and 10% nitro.
    Thus far, I am very well pleased with this engine!
        Tia,
        Frank
Re: Needed: Operating suggestions for a Broback .25.
« Reply #1 on: July 11, 2014, 08:02:51 PM »
     Hi All:
  I doubt that you will break it running it rich. I would read what Bob Reeves has said on the topic of Brodak 25s. He was running 6" of pitch, as I recall. I would search for that here in the archive, then try it your way, then his way, and see which way works best.
    I don't have one, but several people had them and they seemed to work pretty well.
« Reply #2 on: July 12, 2014, 11:04:06 AM »
  "  I think that I have read that these engines should be operated on the lean side to enable them to run at the correct clearences due to their construction materials.  Can these engines be damaged by running too lean  "
Hi Frank
Yes they can be damaged by a too lean setting, as can any engine. So be careful with a too lean setting.
Try to run a wet, or rich 2 cycle with the Brodak 25, or they will do a 4/2 break, you are going to use between 4 and 6 inches of pitch, depending on how you run the engine
Offline Balsa Butcher
  • High Desert Flier
« Reply #3 on: July 12, 2014, 07:29:38 PM »
The B-25 instructions state that although they can be run in a 4x2x4 fashion more power will be attained running them in a rich 2 stroke with lower pitch props. I have found that to be the case and presently run mine in the fashion you described in the first post. I have also found that the stock tube muffler works better than a tongue muffler, others experiences may differ.  8)
Pete Cunha
Sacramento CA.
AMA 57499
