  • June 14, 2025, 10:46:42 PM
Author Topic: blank  (Read 1311 times)
Online Rusty
blank
« on: November 14, 2021, 06:12:56 PM »
blank
« Last Edit: March 10, 2022, 12:12:03 PM by Air Master »
Offline pmackenzie
  • Pat MacKenzie
Re: Need to hire machinist, small job.
« Reply #1 on: November 14, 2021, 09:55:50 PM »
If it is a Nelson, then probably it takes a Nelson plug, not a "Turbo" plug.
Nelson plug is bigger in OD than a regular or a Turbo, so the head button can't be simply drilled out to take a regular plug.
That aside, the timing on the Nelson is probably not going to be optimal for a typical sport model.
The fact that it uses a non-standard plug tells you that it was designed for making horsepower.
I could be wrong, but not sure Henry ever made a "sport" version of the 40, just the Quickie 500 version.
It is possible that a PA40 head button might fit the Nelson 40 and take a regular plug. Check with Randy Smith to see if that is the case, and if he has any spares.
If you do put it on a Magician , be sure to take video :)
MAAC 8177
« Reply #2 on: November 16, 2021, 03:23:00 AM »
I'm with P-Mac....I want to see the video!
The Divot
« Reply #3 on: November 16, 2021, 02:33:43 PM »
I presume you've converted your Ferrari to a minivan to haul the Magician to the field.
Offline Dan Berry
« Reply #4 on: November 16, 2021, 04:50:05 PM »
I would be interested in seeing the debris field after a Magician with a Nelson40 does a loop.
It will almost certainly use a Nelson plug which is a different beast from a turbo plug. They aren't real hard to acquire. The used to be very reasonably priced. Now they're eight bucks which is still on the low end of prices for plugs.
