  • June 20, 2025, 10:20:58 AM
Author Topic: Older Merco engines  (Read 1711 times)
Offline Bootlegger
Older Merco engines
« on: June 25, 2016, 02:23:42 PM »
  I have an older Merco 35 stunt engine and was wondering if all castor fuel should be run in it, I'm thinking about 22% castor, and maybe 3-5 %  synthetic to keep it cleaner.
  Also I have this fuel in 10% Nitro, also what would be a good prop to use??
   T I A...
8th Air Force Veteran
Gil Causey
AMA# 6964
Online RandySmith
Re: Older Merco engines
« Reply #1 on: June 25, 2016, 02:30:07 PM »
   T I A...
you can run that and it will work well with the synth oil
or you can run  20% all casor with  7&  synth added
or 1/2 castor 28&  oil
the 10 nitro  is good
Offline Bootlegger
« Reply #2 on: June 29, 2016, 08:24:53 PM »
   Thank ya' Randy...
Gil Causey
AMA# 6964
Offline Manuel Cortes
« Reply #3 on: June 30, 2016, 01:01:09 PM »
Hi all.
In the begining, is interesting to know the model of the British Bulldog you are running.... there are several and a way diferent....some very good, others not so....bad for fishing weight  HB~>
The best were the red head from the late fifties, but there are some usable.
If you post a photo I can tell you more....
Kind regards from Spain.
« Reply #4 on: June 30, 2016, 07:26:50 PM »
Hi Gil,
If it is the older Red Head they were excellent stunt engines.  Frank Warburton used a RH .35 in his Tony to win the British NATS.  And it is no small model.  Like Randy always says, 28% oil with about 20% castor.  Sounds like you are on the right track.  For stunt use a 10X5, 10X6 Top FLite paddle blade style prop seems to work good.
BIG Bear
RNMM/AMM
