  • July 12, 2025, 07:58:17 PM
Author Topic: Need copies of paperwork for OS 46AX  (Read 843 times)
  • Gravitywell
« on: July 27, 2012, 07:50:30 PM »
Hi everyone.  I have a new-in-box OS 46AX that I purchased of the internet.  It is missing all the paperwork. HB~>  If someone could scan them and email me a copy, I would greatly appreciate it. H^^  Any hints or tips on running this motor will be much appreciated as well.
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
Re: Need copies of paperwork for OS 46AX
« Reply #1 on: July 27, 2012, 10:53:16 PM »
Glenn,
Is this an R/C engine with a carburetor or has someone added a venturi and needle valve?
For a set up to start I would get a 270 diameter venturi with an aeroproducts needle valve assembly, add 1 extra head gasket (.008 thick shim), use a hot glow plug like an Enya #3 or a Thunderbolt R/C long, and start with a 12 X 4 APC prop.  Should be happy in the 9,300 to 9,500 RPM range.
From there it will depend on how it reacts.
  • Gravitywell
« Reply #2 on: July 27, 2012, 11:10:34 PM »
Hi Randy.  Yes it has been converted to control line.  It has three different sized venturies.  I'll make a head shim and see what it does.
I read your reply in the other thread and it looks like I will be putting this one up for trade for an La.46.  No sense in mucking around with it as I really don't want to make any ship bigger than the Spitfire.  Even it is a tad bigger than I want....but its a Spitfire!! LOL
I want to thank you for your help.  I never was comfortable with this engine as I couldn't find anything on her, so thanks for setting my mind at ease.
Glenn Reach
Westlock, Alberta
Offline L0U CRANE
« Reply #3 on: July 28, 2012, 12:42:31 PM »
Glenn,
If you really want the manual, try os engines.com.
They have them in pdfs for more engines than even I thought they made.
Randy C's comments should serve really well, if you do want to use your AX.
\BEST\LOU
  • Gravitywell
« Reply #4 on: July 28, 2012, 12:54:15 PM »
Hi Lou.  Its funny you should mention that, I just found their site before coming to SH this morning! LOL  Thanks for the tip, it will come in handy for a couple of other motors I have. H^^
Glenn Reach
Westlock, Alberta
