  • July 05, 2025, 02:58:12 PM
Author Topic: Need B40 case  (Read 1116 times)
Offline Lyle Spiegel
Need B40 case
« on: September 13, 2007, 04:35:34 PM »
Due to crash damage to muffler mounting hole, I need new case for B40. Tried to order from  B mfg and also Virginia Hobby- both out of stock. Any help locating new or used case would be appreciated.
Thanks in advance.
Lyle
Lyle Spiegel AMA 19775
Online Bill Hummel
Re: Need B40 case
« Reply #1 on: September 13, 2007, 05:05:17 PM »
See what happens when you try to do a 3 foot loop?  Better flights are ahead...!
ama 72090
Re: Need B40 case
« Reply #2 on: September 14, 2007, 10:27:58 AM »
I guess I still haven't totally unlearned my combat flying style. My trusty VooDoo with Johnson CS would make that turn every time- as would the Quicker and the Sneeker. Just for grins & giggles it would be a hoot to build a new combat wing and re- live that golden era!!
Re: Need B40 case
« Reply #3 on: September 18, 2007, 12:10:53 PM »
Just buy another motor, then you will have a spare piston/cylinder/rod/crank/backplate/propdriver/screws.
steven yampolsky
Re: Need B40 case
« Reply #4 on: September 18, 2007, 01:59:41 PM »
Any chance you can JB Weld a piece of threaded rod and use a nut on the side of the muffler?
Lyle, you and I are now members of the very exclusive club of "B-case breakers"! We should get leather club jackets or something!
Offline Mike Scholtes
Re: Need B40 case
« Reply #5 on: September 20, 2007, 11:37:47 PM »
I'm afraid I need to join the Brodak Breakers club too. Kersplat on pavement and the muffler and half of the rear muffler lug went sailing. I tried JB welding the broken muffler itself and also the lug area on the engine. Lasted about three seconds after I started the engine. I did clean the broken aluminum surface what seemed like really well. I could try JB Welding a stud on the threads where the lug sheared away, but not confident it would adhere any better. Anyone have success with JB Weld on aluminum?
Re: Need B40 case
« Reply #6 on: September 21, 2007, 08:57:49 AM »
Ed Ruane reported on using some aluminum "brazing" rods meant for hobbists, IIRC.  It reportedly works great.  Let's "page" Eddie!
Bill <><
