CLICK HERE--><--CLICK HERE
mystery engine run
Started by Allen Eshleman, August 06, 2026, 10:31:12 AM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Allen Eshleman
I have an LA 40. It runs 11 minutes on 4 oz. of fuel but lacks on power.  I think its's a Randy NVA. Would this indicate the possibility of a wrong size venturi?
Dave_Trible
IMHO....it indicates it's an LA .40...pretty much worthless for anything but lazy sport flying.   The FP .40 and the LA .46 are pretty decent engines.  They missed the boat with that engine.
You might try opening the venturi up-you may gain some performance until needle settings gets critical and runs completely unpredictable,  then back down a step or two to regain control.   That will be all you can expect.   You can also go up in prop pitch and see if you can gain some traction.    I doubt any amount of engine fiddling will be enough to matter.    I would just go to eBay and shop for the .46 or an FP.   These two also have different characteristics but can be sorted to work well.  The FP will only be happy running in a full throated two cycle and the LA .46 can run slower with a bigger prop and show some 2-4 breaking ability.
Colin McRae
#2
Quote from: Allen Eshleman on August 06, 2026, 10:31:12 AMI have an LA 40. It runs 11 minutes on 4 oz. of fuel but lacks on power.  I think its's a Randy NVA. Would this indicate the possibility of a wrong size venturi?
A little additional info might be helpful
-what prop R U running?
-venturi ID size?
-spray bar diameter?
I had a 40 LA on a Nobler ARF. It ran fine but I decided to change it to an Enya SS 35 EX only because the 40 LA was quite heavy for the Nobler requiring a bunch of tail lead. But the engine ran fine. My 40 LA setup on the Nobler ARF:
MAS 10.5-4 prop (cut down from a 11-4)
Around 11k rpm on the ground
0.257" venturi (smaller than OS stock from a 25 LA)
NVA from Bobby Brooks (spray bar dia 3.5mm)
Stock muffler setup
Muffler pressure
VP AIR 10 nitro / 18% oil fuel
4 oz tank
Ran in a 2-2-2
7.5 minutes on a full tank
Colin
Tim Wescott
If you go eBay shopping, add the Tower 40 to Dave's list.  It's basically a 40FP clone.  If you get one with a muffler, be happy -- it's basically a 46LA muffler at about half the weight.
How crusty is your engine?  While those symptoms are what people report for the 40LA, they're also what people report (and what I've experienced) for an engine that needs a good soak in a crock pot.  If you haven't cleaned it in a while, or if it didn't come to you in never-run condition, you may want to consider giving it a good bath.
Colin McRae
#4
Quote from: Dave_Trible on August 06, 2026, 04:13:12 PMIMHO....it indicates it's an LA .40...pretty much worthless for anything but lazy sport flying.  The FP .40 and the LA .46 are pretty decent engines.  They missed the boat with that engine.
Not been my experience. I have run both 40 and 46 LA's and have not noticed much of a difference on how they run, just that the 46 offers a bit more power. Two other flying buddies also have 40 LA's on a couple models and both run fine.
One thing I have noticed is that IMO the stock LA venturis (effective areas) are a bit on the big side. I typically run slightly smaller venturis from the OS stock size on 25/40/46 LA engines. And I have only run with the OS stock mufflers (with cone insert). I tried a tongue muffler once on a 25 LA and did not like the engine run. Went back to the OS stock muffler and engine ran great.
I have read from time to time that people don't particularly admire the 40 LA, but I really don't know why.
Colin
Brett Buck
     Does it have a stock venturi and a Randy NVA? Then, yes, the engine has been damaged (a hole drilled in it) to accommodate the oversize spraybar. The LA40 uses the same size spraybar as the others - 3.5mm (.137). I think the Randy/Nelson (which I do not have to measure) is more like 3/16, which is a *drastic* reduction in power. If someone has one to measure, tell me, and I can figure out the likely power drop with a stock venturi.
   Given that it has already been damaged/modified for the spraybar, it may also have other damage/modifications, which is more-or-less always in the direction of less power. You didn't do much description, but I have seen 40 and 46LAs that were damaged/modified by a moderately-well-known modifier to have *way* less power than a Fox 35, and ran nearly no fuel for a normal run. Depending on the damage, it may not be easily repairable.
    I am not sure what Dave is talking about, the *stock* engine works pretty well, far better than a 40FP (although not as strong), just a little less stable than a 46LA. That's why everyone is running the 46 over the 40. Both have plenty of power.
Motorman
The PA NVA is .156" And this will reduce the intake area a bit. Another big drop in power would be from someone machining out the head for lower compression or adding too many head shims (more than one). Also, the condition of the cylinder plays a part. Some of the LA series cylinders, not good to begin with, deteriorate quite rapidly and more so in the hands of an eBay RC flier. The LA40 block is a big heat sink, you don't want to de-tune it or under prop it.
MM :)
Dave_Trible
Quote from: Brett Buck on August 06, 2026, 08:58:06 PMDoes it have a stock venturi and a Randy NVA? Then, yes, the engine has been damaged (a hole drilled in it) to accommodate the oversize spraybar. The LA40 uses the same size spraybar as the others - 3.5mm (.137). I think the Randy/Nelson (which I do not have to measure) is more like 3/16, which is a *drastic* reduction in power. If someone has one to measure, tell me, and I can figure out the likely power drop with a stock venturi.
Maybe my sampling was small-just one engine- but it wasn't friendly to operate,  didn't start well and mostly lacked power.   I felt I could get more thrust from a McCoy .35.  We gave up on that one early.  I think it lurks in my son in laws basement someplace.  We reverted to the FP on that airplane and didn't look back.  I also wasn't fond of my first LA .46.  I think it had QC issues. It was terrifically tight.  Still very tight after more than two hours on the bench.   It never showed us much.  A couple later ones serve us well.   I have one that I got from Charlie Reeves.   That one will pull a truck on 12" carbon props.   I sorta doubt it's stock...
Reptoid
Telling people that their engine is "damaged" or "ruined" because the needle valve holes were enlarged is a little bit extreme. The standard OS NV assembly has a diameter of .138" (3.5mm). Most aftermarket NV assemblies including the PA's from Randy at Precision Aero are .157" (4mm). The only spraybars I have encountered that are larger than 4mm are Dubb Jet's. All you have to do to get equal area (equal performance) is use a slightly larger venturi.
Examples:
A .233" dia. venturi with OS spraybar = a .255" dia venturi with a 4mm sprayber.
A .252" dia. venturi with OS spraybar = a .272" dia. venturi with 4mm spraybar.
A .260" dia. venturi with OS spraybar = a .282" dia. venturi with a 4mm spraybar.
A .275" dia. venturi with OS sparybar = a .296" dia venturi with a 4mm spraybar.
Like Like x 2 View List
       Don
       AMA # 3882
Colin McRae
Quote from: Reptoid on August 10, 2026, 04:43:40 PMTelling people that their engine is "damaged" or "ruined" because the needle valve holes were enlarged is a little bit extreme. The standard OS NV assembly has a diameter of .138" (3.5mm). Most aftermarket NV assemblies including the PA's from Randy at Precision Aero are .157" (4mm). The only spraybars I have encountered that are larger than 4mm are Dubb Jet's. All you have to do to get equal area (equal performance) is use a slightly larger venturi.
Examples:
If venturi effective area is the issue at hand, the OS stock design effective area for the 40 LA is 0.0257 sqin.
With a 4mm spray bar the venturi throat dia would need to be 0.300" to hold the same eff area.
Would it not just be easier to purchase a 3.5mm NVA spray bar NVA from Bobby Brooks (matches OS stock size), use the OS stock venturi, and not bother with drilling out the case?
Colin
Reptoid
Quote from: Colin McRae on August 10, 2026, 08:11:38 PMIf venturi effective area is the issue at hand, the OS stock design effective area for the 40 LA is 0.0257 sqin.
Colin
You missed the point. Of course if you have a stock case you can use the appropriate size for the OS sparaybar.
The point was; if your case is already drilled to 4mm the issue can be solved by simply using the larger venturi to match the larger spraybar.
   By the way your number for the stock LA 40 effective sq in area is incorrect.
OS LA 40's came with two different size venturi's depending on vintage or batch; .265"(.019 sq in effective area) or .282" (.024 sq in effective area)
       Don
       AMA # 3882
Steve Helmick
#11
Pete Ferguson had an OS .40LA on an ARF Cardinal that worked fine. Thunder Tiger 11x4.5 prop, 10-22 fuel, Randy Aero CNC tube muffler. I'd have to guess at the spraybar dia. and venturi bore, but IMO a .271" bore with a .156" spraybar is going to work pretty well. The reason for the Randy muffler was to adjust the CG, nothing else. I might drill out the muffler outlet as big as possible, though.
I'd wonder what the OP's venturi/spraybar sizes are, and also if the glowplug was tight and didn't have a leaky seal. 4 oz of 10% nitro for 11 minutes tells me something is wrong, for certain.
I keep nagging the Sunday morning donut crew to warm up their engine BEFORE setting the needle, and USE A TACH to do it...but they apparently like crappy flights. Mysterious! Steve
Edit: Just now noticed I had typed in ".146" instead of ".156" spraybar diameter, so fixed it...a month+ late.
