  • June 21, 2025, 11:53:55 PM
Author Topic: Mystery Engine - Help???  (Read 964 times)
Offline Ralph Wenzel (d)
« on: July 30, 2007, 09:28:28 PM »
Don't know what it is; no clue. Hard to see, but there's an "LD" and a set of "Pilot's Wings" on the cylinder base. Homemade diesel"?? One photo has a ruler drawn for size reference . . .
Ralph Wenzel
AMA 495785 League City, TX
Offline Bob Zambelli
Re: Mystery Engine - Help???
« Reply #1 on: July 31, 2007, 06:12:07 AM »
It's a Mite Diesel (compression ignition).
« Reply #2 on: July 31, 2007, 10:47:49 AM »
Yep, Bob, I checked the American Model Engine Encyclopedia and this thing looks very much like a "Mite" Diesel, .099. from 1947. Thanks for the quick answer!
Ralph Wenzel
« Reply #3 on: July 31, 2007, 11:21:02 AM »
Ralph - check out that little gadget under the crankcase - it's an air bleed valve.  n~ n~ n~
If you get the engine running (  ~^ ) and it runs badly, you can adjust the valve and it will run worse!!  LL~ LL~
They also made a glow version. I have both but I've never run them.
