Hello Steve,
No rubbish fuel for my engines! I use only the best available. I use the same stuff in my TT42 engines. I have had short lives with my LA46 engines. Usually the compression goes after a couple of hundred flights or less. I have then put in new P/Ls and by the time they lose compression. the bearing bush is shot. OK, they give a very good stunt run, no doubt about that. However I find the TT42 to last much longer and give a better stunt run. They are simply better quality engines than the LA series.
Jerry, if you can't machine a venturi to bolt on a TT42, then the simple answer is to buy a venturi from Len Neumann over on Stuka Stunt.
If you ever buy a piston liner for an LA46, try some measurements on the bore. I did and the 3 I have had so far have been out of round by between 2 and 3 thou (measured with a professional bore gauge). That confirms my feelings that the LA series are not exactly the best of the budget engines.
Look, if you are happy with your LA46s then fine, I am sure I must be in a minority. I just like the TT42 better than I do the LA46!
Andrew.
